603,403 active members*
3,893 visitors online*
    Sep 2006
    1738
    PC Monitor, Vertical - Horizontal - Want Horizontal
    Hey all,
    I have a large wider screen that would be more appropriate in the vertical position due to my shop constraints. I have mill running Win7 with Mach3, I can change the screen to be set for vertical but MACH3 does not conform to the resolution.
    Is this going to require a custom screen set or does the stock have the ability to conform to the new resolution.
    Thank you,
    Cheers.
    -Jason
    Sep 2006
    1738
    Re: PC Monitor, Vertical - Horizontal - Want Horizontal
    BRAIN FART....
    I want the monitor vertical, not horizontal as in the title. It's like a 22 inch monitor and it would be nice to have the space freed up going vertical and I feel like the software would be better suited in the vertical position.
    Regards,
    -Jason
  1. Monitor's horizontal hold affected by heat
    By ddgman2001 in forum Fadal
    Last Post: 07-13-2013, 01:41 PM
  2. ATC for vertical & horizontal machining centers
    By maylin1105 in forum News Announcements
    Last Post: 03-02-2012, 04:19 AM
  3. Horizontal vs Vertical Machining Center
    By B.Reilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 08:09 PM
  4. horizontal and vertical control
    By makenparts in forum Bridgeport / Hardinge Mills
    Last Post: 05-18-2011, 12:49 AM
  5. carusel horizontal o vertical
    By matriceria_fae in forum Spanish
    Last Post: 08-08-2010, 02:30 PM
