603,374 active members*
4,171 visitors online*
Results 1 to 6 of 6
    Oct 2004
    51
    PCB End Mill?
    Not sure if this is the correct forum for my question but I'm looking into PCB routing and have done some research but I can't find any supplier who sell's very tiny end mills? I want say 8 or 10thou. trace to trace mill outs...
    Dan
    Dec 2004
    1316
    Try www.thinktink.com. They have a wide range of small end mills including v-tip isolation tracing bits.
    I used a 0.8mm end mill for this board, my first.
    Jason
    Oct 2004
    51
    Thanks.
    Dan
    Mar 2006
    1625
    here a few more names mircocut and a link http://www1.mscdirect.com/CGI/NNPDFF...=349&PMCTLG=00
    Oct 2005
    1237
    Quote Originally Posted by Jason Marsha
    Jason
    Cutter life would be extended if you just isolated the traces and didn't machine away large areas. Anything to save a buck. Nice looking PCB by the way.
    Dec 2004
    1316
    Thanks MrWild, I agree on about cutter life extension but after seeing both results I preferred removing all the copper except the traces.
    Jason
