587,683 active members*
3,236 visitors online*
Page 1 of 2 12
Results 1 to 20 of 37
    Jan 2007
    219
    Exclamation PCI Parallel Port Card
    I am looking for a PCI parallel port card card that is known to work with mach 3. I have tried 3 different cards and none of them worked. If somebody could tell me where I could buy one I would really appreciate it. -Adam
    P.S. I am looking for one that is as low profile as possible.
    Mar 2003
    35538
    www.rogersmachine.net and www.candcnc.com both sell cards that they use with Mach3, but just about any card should work. What didn't work with the three you tried? Are you sure you entered the correct port address?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2003
    1475
    PCI Parallel card from CompUSA
    I baught my PCI parallel card from CompUSA for I think $15. And it worked fine the first time.
    Good Luck:rainfro:
    Jan 2007
    219
    Do you know what brand card it was?
    Jul 2008
    35
    Quote Originally Posted by Adamj12b View Post
    Did you figure out what the problem was? I am having similar problems.
    Aug 2007
    422
    where can I figure out what the address of my port is? I am running windows xp and mach 3
    Aug 2007
    422
    ok, I figured it out last night, i get 5v out of my port now but when the relay for the spindle / coolant turn on those pins drop to 1.4 volts. what's up with that? the relays do activate and hold but why such a drop??
    It might be to do with the current being drawn by the relays, you might be better off using your PC's 5volt to power a transistor and let the transistor pull the relay in using a seperate 5volt supply or better still use an opto isolator instead of a relay as they have a lower power consumption.
    Andy
    Aug 2007
    422
    can you provide a schematic and part numbers? I thought that was the problem but wasn't sure.
    I'm at work at the moment, but will look into when I get home, someone else might pop in in the mean time and give you a better solution but I will look it up when I get home and post a reply.
    Andy
    Aug 2007
    422
    thanks!!
    In the mean time have a look here it might help.
    http://www.epanorama.net/circuits/parallel_output.html
    Jun 2007
    3735
    Smile Great link.
    Thanks audioandy1762.
    That link explains and assists in the intricacies of I/O under later OSs.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Aug 2007
    422
    audioandy1762
    great link! helps to understand why i am getting the drop in volts. now I guess I need to build an isolator (3 actually, spindle, air selenoid, vaccum clamp)
    Hi glad you both found the link helpful.
    rcpilot I have a book "Real-World Interfacing With Your PC" by James Barbarello the following is from that.
    Use a 4N25 or 4N36 these are a 6 pin opto connect a 100 ohm resistor to pin 1 then connect your output from your PC to that , pin 2 goes to your PC chassis or earth. No connection to pin 3, connect a resistor to pin 4 between 1 and 10 k this goes to the negitive side of your seperate 5v supply, pin 5 will go to your relay and pin 6 will be connected to the positive 5volt seperate supply. For true isolation keep your 5volt supply negitive and your PC ground seperate.
    Hope this helps
    Andy
    RC just check the the above OPTO's will handle the current of your relay, if not just have a look on your componant suppliers web site and find one that will. Do you know the resistance of your relay coil? If so you can work out the current draw of the coil.
    Andy
    PS hope I'm not confusing you
  17. #17
    Jun 2007
    3735
    Lightbulb
    Quote Originally Posted by audioandy1762 View Post
    Andy
    It's won't handle any extra current because the current transfer ratio of the opto-coupler is not high enough.
    You will just get isolation nad not damage the PC.
    You need something like a ULN2003 7 channel darlington driver to get enough current to drive the relays, unless the relays are really tiny, and they would not be able to switch the power.
    The ULN2003 can drive 0.5 amps per channel but not all at once.
    The total output is limited to 0.5A because of heating.
    You could use multiple drivers and they can operate a 12v relay, and have the built in protection diodes (as long as you connect pin 9 to the relay supply)
  18. #18
    Thanks Neilw20 for clearing that up, I posted my last post after looking at the data sheet for the two opto's.
    Hope we have put RC on the right track between us and he gets his problem sorted.
    Andy
  19. #19
    Aug 2007
    422
    Thanks for the info, I am not too confused as I have some backgound in electronics, it's just been a while. I'll look into the parts and see what I come up with.
  20. #20
    RC come back and let us know how you get on.
    Cheers
    andy
Page 1 of 2 12
  1. C++, Win XP, Parallel Port
    By Zumba in forum Coding
    Last Post: 03-29-2012, 07:12 PM
  2. 2nd PCI Parallel Port
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2006, 09:17 PM
  3. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  4. pcmcia parallel port card ?
    By WsW-WYATT in forum DNC Problems and Solutions
    Last Post: 09-07-2005, 12:29 PM
  5. Parallel Port
    By Shanghyd in forum Computers / Desktops / Networking
    Last Post: 11-22-2004, 06:56 PM
