588,621 active members*
5,687 visitors online*
Results 1 to 15 of 15
    Oct 2013
    84
    Unhappy PCNC1100 Power drawbar issue
    After running a setup for 2 hours my power drawbar stopped closing the collet for some odd reason during tool change, if I press the lock button on the pendant or the foot switch the collet closes fine. If I change a tool using PathPilot, the collet doesn't close which then drops my tool after tool change. When i press the collet close button under ATC tab it doesn't close the collet at all? Any idea anyone.. broke 2 endmill and ruin a part already. thanks in advance!
    Jul 2004
    1424
    Re: PCNC1100 Power drawbar issue
    I would check the wiring between the PDB circuit board (in the little box on the top of the mill head) and the ATC Controller (in the back of the column) and make sure everything it plugged in (The RJ11 cable going from DB3 at the PDB controller to J5 on the ATC controller). If so, unplug the wire and check continuity between pins.
    Sounds like an electrical connection problem.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Mar 2009
    1863
    I don't have the ATC on my 1100, and after some stories I have read like this one, I'm glad I don't.
    The ATC wasn't available when I bought my machine. It came about 4 months later. But I had already decided for $4200.00 I could change the tool a whole bunch of times by hand, and after 5 1/2 years, I have not regretted my decision.
    And I still run the Mach III operating system.
    Jun 2005
    655
    For a counterpoint, I've had a few issues and broken tools with my beta PDB and ATC and yet still wouldn't hesitate to get another one.
    It sounds like the problem is electrical in that somehow the PDB control board isn't getting the drawbar signal for some reason.
    Oct 2011
    477
    Quote Originally Posted by Steve Seebold View Post
    My ATC has more than 50,000 changes on it based on only one of the parts we run alone.
    Lets see $4200/50,000 = $0.084 per change.
    Yeah, I would do it again.
    Had to replace a couple of worn out fingers, realign several times and go through a bag or two of a 100 nylon bolts but overall it has been great and I don't have to be standing there when it is time to change tools. I can change bolts in under 2 minutes, looks like a NASCAR tire change from the side.
    gary
    Mar 2008
    216
    Quote Originally Posted by nitewatchman View Post
    My ATC has more than 50,000 changes on it based on only one of the parts we run alone. ...
    Gary:
    Based on your self portrait you could certainly use all of the rest that your ATC provides for you.
    Oct 2011
    477
    I'm from East Tennessee where you go to family reunions to pickup chicks!
    Oct 2011
    477
    Me and my oldest son.
    Oct 2013
    84
    Sorry for the reply and thanks helping out. Looks like i may have found the problem, see attached images. Looks like the solder pad on PCB may have lift and doesn't have any contact on the board, I can wiggle the telephone jack and the actual solder part is actually moving. I'll try to bypass the solder part temporarily until i get a replacement part.
    Attachment 341496
    Attachment 341498
    Good to hear you found it. I figured it was a connection issue.
    BTW I too have a beta PDB and ATC, been running weekly since installed, yes many years. They just keep on running. It's nice to be able to cut material or do assembly while the machine continues to crank out parts.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Jul 2007
    1602
    gary
    Just curious, do you change the bolts on a schedule, upon inspection or do you wait for a failure?
    bob
    Oct 2011
    477
    I usually just replace when an "event" strips or breaks them.
    I have found that if I run for extended periods (days) without referencing the carousel the rotation seems to develop and error and the tool change will fail. It's not a big deal unless dropping the cutter chips an edge. I buy the screws from McMaster-Carr and they are really cheap.
    gary
    May 2010
    327
    I've shared this elsewhere but figure I'll chime in here too.
    I changed the nylon bolts to 1/2" longer versions, and use nylon nuts on them. When an event happens (which is rare), the longer bolts/nuts keep everything together so the tool doesn't fall out of the ATC forks. It strips the nut or bolt, but no big deal. Simply pull the tool out, clean things up, replace the bolts/nuts and go again. I'd guess I have an event maybe once every 1,500-2,000 tool changes, and likely less. If I ever take the time to properly adjust the controls on the air cylinder so that tool tray doesn't (almost slam) into place every now and again, I'd bet that number would go to 10,000+
    WW
    Manufacturing & Development
    ThermaeCooling.com
    Aug 2013
    980
    Which McMaster # for the screws you use?
    Thank you!
    gary
    Oct 2011
    477
    I have used both 16mm and 20mm. The 20 mm are a little easier to install for me.
    I have used about half a bag of each in the last 4 years. This includes replacing screws after an "event" and a few wholesale replacements of all the screws.
    The screws are basically a fuse to prevent worse things from occurring. I also just install the screws snugged and not really overly tight. This will allow the ATC finger to align as the TTS tool enters the spindle, I run the PBD very tight so the tool shank enters the spindle collet with some drag, The top ends of the holders are radiused to ease the alignment and entry of the holder into the spindle. I am sure that this also contributes to future bolt failures but I have very little trouble with tool pullout, a very rare occurrence.
    https://www.mcmaster.com/mva/library...99602a520l.gif
    https://www.mcmaster.com/mva/library...99602a525l.gif
    https://www.mcmaster.com/#99602a525/=15bpruz
    https://www.mcmaster.com/#99602a520/=15bpsei
  1. PCNC1100 Power draw bar info needed.
    By andyf97 in forum Tormach Personal CNC Mill
    Last Post: 12-13-2015, 06:22 AM
  2. Stupid drawbar issue with Fadal VMC15XT.
    By lenimal in forum Fadal
    Last Post: 08-04-2015, 07:33 PM
  3. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  4. Tormach Stand PCNC1100 115vac Power Rating?
    By agurkmedia in forum Tormach Personal CNC Mill
    Last Post: 10-25-2014, 03:43 PM
  5. X2 power drawbar
    By X2cnc in forum Benchtop Machines
    Last Post: 09-20-2008, 01:39 AM
