588,385 active members*
5,481 visitors online*
Results 1 to 4 of 4
    Dec 2009
    Pewter - can it be Laser engraved?
    Hi All,
    First post so be kind
    Anyway, have a nephew that needs a hip flask engraved for a gift. I haven't engraved on Pewter before, have done stainless. Is the procedure the same. Do I need to spray it with Cermark spray?
    Any suggestions would be grateful, Thanks.
    Apr 2007
    327
    Yes it will work with Cermark but it will take a lot more power than stainless. I have a 30 watt laser, 80 ips, and mark stainless with 100% power, 10% speed. I don't recall exactly what I used for pewter, but I think it was 5% or less speed. I would recommend figuring out a way to hold it in place so you can apply the Cermark, laser it, wipe with a damp cloth and, if necessary, reapply Cermark and laser again. The only thing lasering with too much power will do is make the mark grayish/tan in color. You could reapply and laser again with less power and it will darken up.
    Gary
    Dec 2009
    Thanks Gary,
    I too have a 30 watt Laser (Epilog). I would hate to muck it up and can't really test on anything (unless we had two), but thanks.
    Quote Originally Posted by bubbs64 View Post
    Hi All,
    If the flask is original pewter, laser engraver can do engraving on it directly. you need to spray a cover on the flask, then to finish the engraving.
    www.yorklaser.com
    [email protected]
  1. Roland Egx-30a vs laser engraved from ebay ?
    By bluestorm909 in forum Want To Buy...Need help!
    Last Post: 11-20-2013, 11:02 AM
  2. streaks on laser engraved image
    By identilase in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-29-2011, 08:37 AM
  3. custom sub surface laser engraved Crystals
    By cnc-crystal in forum News Announcements
    Last Post: 10-16-2008, 09:59 PM
  4. Require: Small Laser Engraved parts cut
    By ALAN2525 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-14-2008, 01:53 AM
  5. Pewter
    By johnhamm in forum Composites, Exotic Metals etc
    Last Post: 03-30-2006, 10:22 PM
