603,993 active members*
3,248 visitors online*
Results 1 to 4 of 4
    Feb 2011
    423
    phase converters
    Is anyone running a Cincinnati Sabre or Arrow with a phase converter?
    I am thinking about downsizing and moving my shop back home.
    Single phase power is the major obstacle.
    Any advice is appreciated. TIA
    Feb 2012
    I have a 30hp rotary phase converter that I am using to power my Sabre 1250. It is a "CNC grade" rotary phase converter that I have running through a delta to wye transformer. The transformer has +/-5% and +/-10% taps on it. I have all three of my legs balanced nearly perfectly at 238,238,240 leg to leg. I use the same phase converter to power my EZPATH II CNC lathe with no issues. Most people will probably recommend a VFD style converter over the rotary but I have had no problems with mine. I will mention that MAG quoted me $11,000 for the transformer that I found used on ebay for $375 delivered. Good luck.
    Feb 2011
    423
    Thanks for the info. I started out at home with rpc's and Fadals.
    They worked well together but was unsure about the Cincy's.
    Oct 2011
    208
    I'm running an Arrow 750 from a Phase Perfect PT-330. Works awesome. I would highly recommend it.
    I have worked in shops with rotary phase converters, and the Phase Perfect is far superior in every regard.
  1. ROTARY PHASE CONVERTERS
    By WJ MARK in forum Maintenance DIY Discussion
    Last Post: 05-13-2011, 05:32 PM
  2. Phase converters, what is everyone using?
    By zook in forum CNC Machine Related Electronics
    Last Post: 07-31-2008, 05:20 PM
  3. One more about Phase Converters..
    By l u k e in forum Haas Mills
    Last Post: 02-25-2008, 03:00 PM
  4. CNC and phase converters
    By pipelathe in forum Phase Converters
    Last Post: 12-19-2006, 01:11 AM
  5. Digital Phase Converters
    By bigsteve in forum Phase Converters
    Last Post: 05-11-2006, 01:05 AM
