587,529 active members*
3,269 visitors online*
Results 1 to 8 of 8
    Jan 2004
    201
    Phase Perfect Squeak
    My Phase converter has a high pitched squeak and draws about 5 amps at no load.
    This is a phase perfect 20HP
    Manufacturer says this is normal
    Anyone have experience with this?
    Aug 2005
    578
    I have two 20hp and a 10 hp phase perfect. They do make a humming noise. I think they draw a little power at no load. Never had a lick of trouble with them though.
    Feb 2007
    1084
    Mine whines when it's cold, like below 45*F, I remember that from years ago, we now heat the shop 24/7 as it's a full time job to where we were "moonlighting" previously. A little humming or light wining is normal. Excessive??? Is it in a heated shop?
    Jan 2004
    201
    Phase Perfect noise
    It's like a high pitched chirp, which is pretty annoying if nothing else is on but with all other shop noise it's not very noticible.
    I'm thinking about building a vented box around it or putting it outside
    Feb 2007
    1084
    I saw one guys shop and his converter was in the attic, so to say, couldn't hear anything. Mine is in the bottom casting of an engine lathe, where you open the door for access to the lathe motor, works for me.
    Aug 2005
    578
    Are you guys talking about a Rotary Phase Converter or a Digital Phase Perfect?
    Jan 2004
    201
    digital
    talking about a digital, solid state, the noise comes from the high freqency switching supply
    Aug 2005
    578
    Ahh...that's what I thought but then someone said they had theirs in a cabinet under the lathe....
    I'm easily confused. I'm old...
  1. Phase Perfect
    By Lee Olson in forum Phase Converters
    Last Post: 11-04-2009, 11:31 PM
  2. Lifespan of Phase Perfect
    By Shepard in forum Phase Converters
    Last Post: 02-18-2008, 02:25 AM
  3. Phase Perfect Question
    By bvweld in forum Phase Converters
    Last Post: 10-24-2007, 10:58 PM
  4. The Perfect Circle - Need Help
    By ScoobyDoo in forum FeatureCAM CAD/CAM
    Last Post: 01-17-2007, 11:41 PM
  5. The perfect servo driver...
    By vacpress in forum CNC Machine Related Electronics
    Last Post: 05-13-2004, 09:00 AM
