Want does it take to have a photo limit switch instead of regular limits. want would the circuit look like.
Don C.
Don C.
Go here and look up the slotted opto coupler description.
http://electronents.v21hosting.co.uk...plications.htm
Al
Albert E.
Here`s a part number from http://www.digikey.com/ 425-1060-5-ND
I`m going to use these. They work with the bob campbell`s breakout
board. If your using that board here`s instructions for the wiring.
Wire a 1k resistor in series with the anode pin 3 and the +12v terminal and 2 to the gnd terminal and 1 to signal
terminal.
could you draw that circuit out for me? You have me lost.
Don C.
Hi
I am no expert with this wiring. I just tried the photointerruptor
with my breakout board and it worked fine. There is a 1 K resistor
that I soldered to the end of the red wire. This protects the LED
inside the photointerruptor from seeing too much current. If you
don`t include the resistor the LED will burn out.
is that power to the + and - and the switch is between the out to -
Don C
Hi Don C
I don`t understand your question. Here is a doc
that shows the pin layout of the photointerruptor.
http://rocky.digikey.com/WebLib/Shar...ta/gp1s73p.pdf
I got the limit to work but backwards. Im using a pmdx breakout board and I have the limit connected to +5 -5 and pin 11. I'm using Mach2 and it enables my drive (XYZ)axis only when you put something infront of the limit. and I only have it connected to x+
go into your limits configuration and change the "active high/low" setting...then try.
Hi
I could be wrong on this point. I think Mach2 allows
you to configure a high or low for the limit. It might
be possible for you to make this work from the Mach2
software.
under conf. there isn't limits. Under ports and pins there is but no active high low setting that I can see. and it shuts all axis down and I only have x++ checked.
Don
