How can I change the pierce delay in Mach 2. It seems to be sitting there too long.
Open MACH2. Go to Ports & Pins/Spindle Output (may be in another spot in MACH2, haven't run it in over a year). Turn off any Spin-up spin down delay.
Let the Arc Good signal set the pierce delay.
hi redline i had same problem, [was sore on tips], had turned off any spin up/down delays still no good so with some long evenings i found in general configuration look for g04 dwell in ms and click it off or switch it off it worked fine after that..
