603,333 active members*
3,866 visitors online*
Results 1 to 4 of 4
    Aug 2004
    155
    Pilot Arc IGBT
    Jim,
    I spoke with Jason today in Tech-support and he explained the possibilities of a failed IGBT.
    I have a G3-1650 machine and was hoping that you can give me the part number for this item.
    Also, what is the procedure, using a volt meter to test and see if this transistor has failed?
    I did the 5-10 cuts using a 60A nozzle/electrode with a drag shield. The tip looks Ok but I with the age/hours I have on this machine my curiosity has got me thinking.
    Thanks,
    Tom
    Jun 2007
    3738
    You need to disconnect the IGBT to do this test.
    It does not test current carrying ability, but will at least tell you the gate works as it should.
    How To Test An IGBT Transistor With A Digital Multimeter DMM - YouTube
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Aug 2004
    155
    Thanks Neil!
    Feb 2004
    74
    Re: Pilot Arc IGBT
    I know this is a late post. that IGBT is made by Semikron, it has been discontinued and they do not have a functional equivalent.
    So when hypertherm's stock is depleted we're S.o.L.
  1. Spindle IGBT Blown Out
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2010, 03:04 PM
  2. cheap Chinese IGBT pilot arc machines
    By Ed Williams in forum Waterjet General Topics
    Last Post: 02-26-2010, 02:34 PM
  3. How to Observe IGBT QM30DY-H
    By parametric.ms in forum CNC Machine Related Electronics
    Last Post: 12-31-2009, 05:25 AM
  4. IGBT gate driver
    By libbresse in forum CNC Machine Related Electronics
    Last Post: 05-07-2009, 03:14 PM
  5. Prices on IGBT CM150DY-12
    By lester1 in forum CNC Machine Related Electronics
    Last Post: 02-17-2007, 10:11 AM
