603,895 active members*
5,018 visitors online*
Results 1 to 6 of 6
    Jun 2014
    1787
    Planar curves
    I have a problem with curves selected from a polysurface edges, the curves are not planar, extreme magnification makes them show up, is there a command or procedure to make them planar? This is causing problems with Boolean and Boss ops on a part I am working on.
    any insight on this problem is appreciated
    mike sr
    Dec 2009
    167
    Re: Planar curves
    what cad software are you using
    Jun 2014
    1787
    Re: Planar curves
    I have it now, my buddy who is much better in Rhino, directed me to "project to c plane", I couldnt get it to work in the past, as I wasnt giving it a surface for the c plane.
    All is good now.......
    mike sr
    Jun 2014
    1787
    Re: Planar curves
    Quote Originally Posted by squirrel_41 View Post
    Rhino 4 is what I am using, about 4 years now.
    mike sr
    Aug 2009
    610
    Re: Planar curves
    Use project to C-plane and you should be good. I do that a lot for getting my 2D contours on a single layer for later use in Sprut.
    Jun 2014
    1787
    Re: Planar curves
    Quote Originally Posted by pickled View Post
    Thanks Doug,
    Joe told me about that quite awhile back but I never got it to work correctly, I wasnt creating a c plane surface for it to work with, with the surface it works perfect.
    thanks for the reply
    mike sr
  1. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  2. Planar Finishing problem
    By Zuckerbäcker in forum MadCAM
    Last Post: 04-17-2011, 04:21 PM
  3. update to fix slice planar
    By skippyfix in forum BobCad-Cam
    Last Post: 08-19-2009, 03:47 PM
  4. slice planar
    Last Post: 08-14-2009, 09:01 PM
  5. wont planar
    By racefast in forum BobCad-Cam
    Last Post: 02-20-2008, 02:05 PM
