587,765 active members*
3,732 visitors online*
Results 1 to 5 of 5
    Jan 2009
    77
    Planar touchscreen setup
    I just received a used unit that came without documentation. I've downloaded the Elo Touchscreen driver from Planar's archive driver web page, but the setup screen doesn't recognize the installed monitor (which I suspect is the issue). Any suggestions?
    Dec 2011
    161
    IF it's the serial com type, it's like a mess to set up.
    I bought a used one few time ago and every time i rebooted the computer, windows was not recognising the screen, reinstalled and erased like a million times until one day it just worked. Since then, like more than a year ago, not a single problem.
    Jan 2009
    77
    It is the serial type; I have it connected with the 15 pin cable that was supplied with it. The monitor portion worked right away, just plug & play. The touch screen feature; however is MIA. Is there a third cable that should be used? I.E. 1 power, 1 monitor/screen & 1 mouse? Currently I have it setup with just two cables; 1 to power & 1 to the 15 pin on my laptop docking station.
    Dec 2011
    161
    Those two cables should do the job, plug your laptop to the dock, boot it, enter the bios and check if serial port is enabled there. Parallell and serial ports on laptops usually get shut down to save battery on laptops.
    If the bios thing is okay, then try with a desktop computer
    Jan 2009
    77
    The third cable did the trick; once I connected the 9 pin to 9 pin it worked without any other setup. The calibration routines worked & now I am ready to swap it out with my machine monitor. .
    Ready to buy more of the same @ the $43 delivered price that I paid too, but seller only had one
  1. Mach3 with touchscreen
    By Falcon69 in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2013, 01:56 AM
  2. A2100 touchscreen
    By dude-ler in forum Cincinnati CNC
    Last Post: 12-14-2010, 02:55 AM
  3. Replies: 1
    Last Post: 02-10-2010, 07:06 AM
  4. touchscreen keyboard ?
    By dertsap in forum Mach Wizards, Macros, & Addons
    Last Post: 02-07-2010, 02:03 AM
  5. Mach 3 with Touchscreen
    By djgatton in forum Mach Software (ArtSoft software)
    Last Post: 08-04-2008, 08:29 PM
