587,184 active members*
3,475 visitors online*
Results 1 to 7 of 7
    Sep 2016
    3
    Planning out prop4848 build
    Hi All,
    I'm planning out a Pro 4848 build and want to make sure I have my power requirements met.
    I'm going with the Plug and Play NEMA 34 System - Can this run off a 110 20amp circuit?
    I'm also running a 110v Dust Collector and a 110v Router.
    Can I do all of this on a single 110 20A circuit, or do I need more for CNC/DC/Router?
    Thanks!
    Feb 2005
    829
    Re: Planning out prop4848 build
    I run my CNCRouterparts standard machine off of 3 circuits, probably overkill:
    1 - 110v/20amp - for the Nema 34 Controls and drivers
    2 - 110v/20amp - for the control PC and Vacuuum dust collection.
    3 - 220v/20amp - 2.2KW spindle
    And both of those 110v circuits have various other tools running at any one moment as well.
    Only time I ever blew a circuit. I was running a Nema23, Hitachi 12MV and Vacuum off of one circuit. Was right at the edge of power for that circuit.
    So I would say, no you probably can't run all 3 off of one circuit.
    Sep 2016
    3
    Yeah, if you blew the circuit with the router, Nema23, and Vacuum then I definitely need another circuit. I run another 110 and a 220 while I am at it so I can move up to a spindle later.
    Thanks for the reply!
    Feb 2004
    1086
    Hi Chriscos,
    The Nema 34 system draws about 9-10 amps at max load. At 110V, typically a 20 amp circuit is sufficient to run this and a router without an issue, but I would suggest another circuit for your dust collector. It's a good plan to run a 220V line at the same time as you run another 110V line, both so you are ready for a spindle in the future and in case you want to run a larger 220V dust collector.
    Best regards,
    Ahren
    Sep 2016
    3
    Awesome Ahren, thanks for your reply! I'm still doing my due diligence, but hope to place an order with you in the next month!
    Thanks,
    Chris
    Feb 2005
    829
    Get a Spindle ASAP, SO much better! And Quieter!
    Sep 2007
    140
    Quote Originally Posted by nlancaster View Post
    +1 what he said
  1. planning out a build
    By bridgeport13b in forum DIY CNC Router Table Machines
    Last Post: 04-28-2015, 03:08 PM
  2. Planning my build
    By IanFiTheDwarf in forum DIY CNC Router Table Machines
    Last Post: 01-26-2015, 09:18 PM
  3. First Build Help (Planning)
    By Rezort in forum Australia, New Zealand Club House
    Last Post: 11-28-2013, 01:48 PM
  4. First Build Planning (Round 2)
    By Rezort in forum DIY CNC Router Table Machines
    Last Post: 11-25-2013, 04:41 AM
  5. First Build Help (Planning)
    Last Post: 11-15-2013, 04:30 AM
