603,546 active members*
4,101 visitors online*
Results 1 to 5 of 5
    Jun 2007
    268
    Plasma cutting Stainless steel
    I had a guy contact me about cutting out a grill for his tractor from 16 gauge stainless steel. His only concern is that there will be discoloring along the cut edge from the plasma, i havent cut stainless yet but read that if you cut it in water you eliminate the burn marks? if so does the peice need to be submerged in water when cutting?
    EDD
    Jul 2005
    2415
    All steel changes color when heated beyond a certain point. It's hard to see in mild steel with black mill scale. The heat effected area varies based on the time of exposure and amount of heat. The discoloration is a form of oxidation so the air surrounding the cut feeds the process. You can limit the heat discoloration by keeping the metal on either side of the cut below the temperature that causes the reaction. By having the stainless setting on water (water touching the back of the material or slightly submerged) you can keep discoloration to a very narrow area or none at all. You can also remove minor discoloration using several acid based pickling agents.
    TOM CAUDLE
    www.CandCNC.com
    Modular CNC Electronics
    Aug 2006
    74
    Have when cutting stainless, that cutting on a water table stop materiel warping but no so much discoloration, using N2 as a purge, which can be used on air torch, helps with oxidation (no O2, except for whats in the water, which is what causes oxidation). I do a fair amount of polished stainless, and even with all the troubles I have had recently with Fine Cuts, running regular 40A seem to do okay. A little buffing and the discolor is about as noticeable as a laser cut. I'll even add, I leave the laser coat on the stainless when cutting. Just a little more cleanup. But It's better than scratches or arc marks.
    Chip Coale
    Feb 2007
    1084
    Just polish it up with a palm sander when your done. I would start with 100 grit, move to 220 then 400, it will look nice. If you run 16ga dry, I would expect warpage, water table is the way to go.
    Jun 2007
    268
    Thanks guys, i think i may make a water tray to sit on my slats and try it out.
    EDD
  1. Laser Cutting Stainless Steel ???
    By Babba in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-04-2015, 06:45 AM
  2. Cutting Stainless steel on a CNC Router (MultiCam)
    By routski in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:00 AM
  3. cutting stainless steel
    By YANKS_RINKS in forum MetalWork Discussion
    Last Post: 03-21-2008, 10:43 PM
  4. Pls suggest a mill fit cutting Stainless steel
    By szcharle in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2006, 03:22 AM
  5. Cutting stainless steel
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2005, 11:14 PM
