587,760 active members*
2,810 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Plasma/Laser cut parts to build a CNC Router
Results 1 to 7 of 7
    Mar 2004
    439
    Hi All-
    A couple years ago when I first joined CNCzone, I had read a build log about someone who made a router frame from a single 4' x 8' sheet of steel that he had laser or plasma cut.
    He had created an ingenious design so that the edges of the steel were like "finger joints" that interlocked together. http://en.wikipedia.org/wiki/Finger_joint
    He did this so that no jigs were required to align the parts when they were welded together. It appeared that once it was welded, it would make a very strong system.
    I am looking to find this thread, and possibly use this design on a router that I am planning on building. I have tried searching for several key words that may have been in the thread, but I have not had any luck.
    Any help would be appreciated.
    Thanks-
    NEATman
    May 2006
    102
    can't help much although I think I've seen a German one that was laser cut and then glued (presumably he couldn't weld)
    Mar 2004
    439
    la-coterie-
    Was that in a thread here? Or did you see it in person?
    NEATman
    May 2006
    102
    heck, I can't remember for sure, I reckon that I probably got to it from cnczone. I didn't bookmark it If I come across it again I'll post it
    Oct 2004
    26
    May 2006
    102
    yeah that was the one! http://www.tron-cnc.de/ as well
    Mar 2004
    439
    koslaz-
    That's not exactly the one I remember, but I like it -Thanks!
    Lots to learn from the pictures. I'm thinking of trying a 50" x 80" platform, as I have rails and ballscrews to suit that much travel. I'll need to design up my own plans.
    NEATman
  1. CO2 LASER / Build It
    By Chivo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-01-2012, 12:31 AM
  2. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  3. 5 x 10 plasma table build
    By DSL PWR in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-14-2007, 10:09 PM
  4. 1st build: Router/Plasma
    By krebsatm02 in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 03:56 PM
