587,086 active members*
2,894 visitors online*
    Feb 2024
    Plasma Relay wiring question
    My plama torch is not firing and i have attached an image of the inside of my controller showing my bob and my relay board. The wires going into the relay board are as follows V+ from bob to grnd on relay and output 1 on bob to v+ and in on the relay board. The output connection is on the no and nc terminals nothing on common terminal. This doesn't look right to me. Any insight is appreciated. This is a Wright CNC table.
    Dec 2003
    24223
    Re: Plasma Relay wiring question
    What is the method used to produce the Pilot Arc?
    Is it occuring?
    Albert E.
  1. BOB to Solid State Relay Plasma CNC wiring
    By greenjeens in forum CNC Machine Related Electronics
    Last Post: 12-20-2012, 02:29 AM
  2. Relay wiring
    By ozzie34231 in forum CNC Machine Related Electronics
    Last Post: 06-17-2012, 03:15 PM
  3. Wiring Aux 1 relay
    By SWATH in forum Mikinimech
    Last Post: 02-29-2012, 07:26 PM
  4. G540 Relay Wiring - Quick Question
    By strohkirchw in forum Gecko Drives
    Last Post: 12-06-2010, 10:37 PM
  5. embarassing relay wiring question
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 01-15-2009, 02:40 AM
