Hello guys, I am new here, but I am not completely unfamiliar with CNC machines.
It was almost 20 years ago I had the chance to work with a CNC mill, it was barelly powerful to deal with 600 HB hard steel, if I recall right.
Now I am sinking in this passion of mine, after having completely lost contact with such world.
I want to build a 3 axis mill that can work from aluminum to steel. I do know that I will have to make a first attempt far from this standard, but I want to start working right away in the main goal.
Here is some prntscn of the google sketch I did the drawing.
Some considerations:
After looking at many designs, I felt that the X axis would be limited, so I made a table sliding on top of another.
I consider using SBR20 line rail and bearings, supported, and 16 anti backslash ballscrew, and direct drive on X and Y, and pulley reduction on Z 2:1, using NEMA 34 3,4Ncm (481,5oz.in) stepper motors with 3 x Leadshine M542 stepper motor driver, these I can get as a kit.
The construction would be on 50x50x2 mm steel profile, should I go stainless steel? I was thinking about 304.
On the side panels would be 20 mm plating, and wherever looks thinner will be 20mm plates.
It do looks very robust because I am scared of structure deformation affecting the quality of production.
But I guess it will be very heavy?
The chassis have been designed around this values:
Y axis rail length (Base rail): 1000 mm, separated by 600 mm, bearing position would allow 550 mm travel.
X axis rail length (on top of the other): 1500 mm, separated by 450 mm; bearings position would allow 950 mm travel. full length of table structure 1700 mm
Measuring Z I conclude that I got the rails too short, because I have 580 mm between bottom of Z table (spindle support)
z rails length: 500 mm
Z movement range: 200 mm
Because I want a long large spindle shaft, like the one I tried 20 years ago.
With these results in following machine measures (Excluding support table):
Depth - 1320 mm
Height - 1550 mm
Width - 700 mm
Forgive my first rough approach, can you help me getting started?
Is the structure too much? I haven't yet considered costs, I want to get to a effective design first.
Are the stepper motors strong enough?
Thanks to everyone for the input, much appreciated!
Lev
