587,188 active members*
4,438 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Please help with V26 4Th problem
Results 1 to 18 of 18
    Jun 2004
    236
    Hello there, I been fiddling with this all day
    I am going to attempt to attach 3 files,
    1) part
    2) wire frame part
    3) Un-Wrapped feature
    About 1-2 years ago, A member named "Burr Man" helped me with building my post
    for my Fadal
    I sure hope he is OK, I cannot seem to find any recent posting from him, But He
    was a Guru on V26 with these types of issues
    I tell ya, Im really stuck on this one, Its basically a small simple trunion cog the appears
    very simple at first sight, There is 2 components that have to match
    For some reason, I cannot get this darn thing to post, Even in un-Wrap mode
    I suspect the darn stock wizard is really messing with me, I did test some older
    programs, And they post fine
    So any pros out there that can help, I would really appreciate the help
    The CAD drawings are very crappy, Double lines, And even triple features
    Please review the attachments and tell me what the heck Im doing wrong!
    I am trying to Zip 3 files, So bare with me!
    Edit, I think I got attachments uploaded!
    Wayne
    Visit our face book page, search on FaceBook; High-Desert-Precision-CNC-Machining-Nosalas-Hobby-Shop
    Jun 2004
    236
    Re: Please help with V26 4Th problem
    Attacments
    Dec 2008
    4548
    Hi Waynno,
    Sorry, In Cali for another week or so. Will be happy to look when I get back. Maybe Al or JR or another user can open the files and get a look.......
    Apr 2009
    3376
    Hey Waynno.I have no clue on 4th axis work,,,
    But I had a look Nut2.bbcd file.
    I noticed it would not chain select
    so
    I looked harder and this is what I found.
    Delete that extra line and all will chain select.
    All I got for now.
    Apr 2009
    3376
    I opened up Nut Wire Wrap .bbcd and saw this
    Hint,bad geometry is usually the reason you get unsuccessful CAM
    Hope that helps,I really have no idea on 4th axis.
    Jun 2004
    236
    JR, Noticed double lines, I think that is what is giving me troubles, I do have one file that I had erased all doubles
    and triples, But still getting no POST
    That is why I came here for help
    I think stock wizard is messin with me!
    Wayne
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Hey Jr... Maybe look at the stock setup and note the origin location. Then this should correlate to the wrapping groups setting... As in, if he wants to setup the stock zero on top, then the wrapping groups rotation axis should be set to middle, etc.. (negative number to where stock is chucked....
    Or if stock origin is centered on stock, then be sure wrapping group edit is set to diameter of stock rotation.....
    if can't, then maybe tomorrow Al will see this.......
    May 2013
    701
    Quote Originally Posted by Waynno View Post
    Wayne
    As Jr was saying the double geom does have to be clean, I do think it is the stock is giving you the trouble maybe also select 4 axis machine.
    As in Als video the bottom depth of the geom needs to be selected or overlap as in my sample at start and stop may create a problem.
    This is a link to Als video which is a big help.
    BobCAD AfterDark
    BobCAD CAM V25 4 Axis Standard Wrapping and Unwrapping
    Jun 2004
    236
    OK, guys, Thanks a bunch
    Will try some of those suggestions, I did watch the Vid yesterday V25 on Wrapping,
    The group does chain select, and I went back and checked an old wrapping routine I
    did about a year ago and the 4X Fadal post seems be functioning correctly
    It also will generate code in 3X mode, But ya switch to 4X and getting no "A" movements,
    Maybe the part is so tiny, I am missing a resolution setting?
    First off will verify if everything is connecting tangent and no Xtra crap
    Getting back at it today
    Wayne
    Jun 2004
    236
    Guys, Please stand by on this,
    I had asked the engineer to keep all the fillets
    at .032 so I could use a .0625 end mill, Apparently there are no fillets on this
    part, and I have to re-do the geometry to reflect .0156 fillets.
    Its a very small stainless part, and I dont even know If I can make this with a .031 end mill
    I did not realize this until now
    So hang tight, I appreciate the help, The geometry needs to be re-worked to
    work with a .031 end mill
    Wayne
    Apr 2009
    3376
    On closer inspection of the solid model,it looks to be a 5 axis part.????
    fun part for sure
    Dec 2008
    4548
    Hi Waynno,
    Sorry I wasn't around to help out when you needed it.
    Here is your part somewhat setup, so you can reference again if needed....
    First as other pointed out, the solid has some weird bad trimming, but I don't think that may have bothered what you are trying to do? It just renders your solids fillets as not filleted in some places, especially for the unwrap....
    So with that said, I rebuilt the solid and used mostly .01 fillets..... I'm not sure of the requirements on your end, or if that would render this particular model bad, but just as a starting reference to "setup the part and stock", which is where I think your original question was anyway....
    So in the file, you are "unwrapping" the little squiggly contour that goes around. So you have to make your wrapping group the size of that unwrap, or things wont jive up.... So I made the "Stock" in this file the size of the wrapping group, then set the actual stock size as top of part for clearances...
    I did this toolpath with a .03125 end mill....
    You can look at it and sim it and see if anything will strike the bone with what you were looking for help on... Also, if you want to discuss it more, post back....
    Burr
    Attached Files Attached Files
    Dec 2008
    4548
    And a side note, to what JR was pointing out, is after you start to add fillets to the areas that are angled, the actual surface would become a 5 axis part, but the 5 axis part on this is SO SMALL, I don't really think it is something you are concerned about??? Just the note for your information....
    Jun 2004
    236
    Mr Burr, That seems to work awesome cutting air!
    I thinks some fine tuning with the feeds, That may just work m friend
    I really pulled my Back this past Sunday, I have DRs appointment early tomorrow
    Yes, Its .031 end mill, Only 5pc, I think I can make the trunions fit good enough
    Your help Is Invaluable man!
    Looks like my post is working fine
    I will try to cut these tomorrow, I really appreciate the help as always!
    Wayne
    Dec 2008
    4548
    Ok great Wayne.
    Be sure to note that the model I posted has that front area completely rebuilt... So be sure to check it against what your original intent was, to be sure I didn't change something too far off what you had...
    Well, get better.... After if you want, we cant do a quick discussion on setting that up and what was missing from the file you posted, etc......
    Dec 2008
    4548
    Quote Originally Posted by BurrMan View Post
    After if you want, we CAN do a quick discussion on setting that up and what was missing from the file you posted, etc......
    Edit to last post.....
  17. #17
    Jun 2004
    236
    Thanks, I did take the model apart and saw a lot of weirdness there
    I always appreciate a second opinion
    Wayne
  18. #18
    Jun 2004
    236
    Ok Mr Burr, And any interested,
    I did a test on .5 brass tonight
    Im sure Mr Burrs mod to the model will be acceptable
    Please note attached Pic id .5 brass stock, The final part will be 304 0r 316 SS
    Om quite sure the engineer will be satisfied with the test articals
    Again Much thanks, It will get me out of a bind, I could not work out myself
    I really still dont think an upgrade from 24 to 26 would have done me any good,
    So I wish Bob would quite calling me and Emailing for now, We are not on fire
    with work at the moment
    Thanks, I will send this pic to engineering and see if acceptable
    Waynno Out
  1. Please Help. Having problem with CNC driver/card problem.
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 02-09-2018, 05:40 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
