The only thing I would check to see if it is 50hz, although in all probability it will have the tolerance to run on 60hz, Most AC drives or VFD's operate into a bridge rectifier anyway.
Are you operating in a 3 phase shop? If so you probabally alread have a 220v transformer on the premises giving you the 220v, If you have any concerns, you can obtain 3 phase drive reactors from Hammond Transformers etc.
Al.
Albert E.
