603,982 active members*
2,351 visitors online*
Results 1 to 7 of 7
Hybrid View
deadlykitten please, recommend a tool... 07-08-2016, 12:24 PM
deadlykitten Re: please, recommend a tool... 11-13-2016, 09:40 AM
CitizenOfDreams Re: please, recommend a tool... 11-13-2016, 12:09 PM
deadlykitten Re: please, recommend a tool... 11-13-2016, 12:31 PM
Azalin Re: please, recommend a tool... 11-13-2016, 12:26 PM
deadlykitten Re: please, recommend a tool... 11-13-2016, 12:41 PM
deadlykitten Re: please, recommend a tool... 11-28-2016, 03:27 PM
    Jun 2015
    4191
    please, recommend a tool grinding machine
    hello, please, we wish to buy a tool grinding machine, for normal and carbide tools ... where to go ? what to consider ? are they manual / automatic ? kindly !
    Jun 2015
    4191
    Re: please, recommend a tool grinding machine
    hello so far i received quotations for machines as in image 1 - those are toys
    i found the one from image 2, more profi, here : https://www.ewag.com/en/home-page.html
    but they don't have a dealer arround here, and i request viewing how the machine / equipment works before buying it
    Nov 2012
    1283
    Strange thread. "I need a vehicle, here is what I have considered so far:"
    Attachment 339256 Click image for larger version.
    Jun 2015
    4191
    Quote Originally Posted by CitizenOfDreams View Post
    i know that it sounds like this ... fact is that industry arround here is not so powerfull, and all colaborators are much more in classic machines than on cnc's
    we also have classical sector, and a small grinding machine, easy adjustable, but it can not run carbide.
    a lot of dealers wanna sell that "pinky", but i am looking for something better, and so far no dealer replied, except for "pinkies"
    so i wish for a better equipment, and will buy it before we test, or at least to see it working; we don't need something extra, just the normal for tools mostly under o20:
    ... frontal grinding
    ... lateral grinding ; cilinder, helix, flutes
    ... cut broken tools
    of course, not a machine to do all of them
    Mar 2014
    1141
    Do you want to grind drills or end mills or both? If drills it is the answer is easy. If end mill or both, its complicated.
    There are grinders from $10 to $1000 and more.
    Jun 2015
    4191
    Quote Originally Posted by Azalin View Post
    Do you want to grind drills or end mills or both? If drills it is the answer is easy. If end mill or both, its complicated. There are grinders from $10 to $1000 and more.
    hy i just described functions that i need in the previous post ... of course, mills, drills, common stuff
    those pinky toys are from 500 .. 1000 ... 7000 euros / dollars
    i need something above them, but not as profesional as a cnc that also crafts tools, because it is too expensive, and well, is not the case to have such a machine would mean that i have time to learn it and i am sure that i can produce on it all tools that i need
    ps : hoping 2 be father, delphi developer, driving license, machinist, no time for hobby = inginer
    Jun 2015
    4191
    attached one is more expensive than a base cnc, because it is designed for watches, thus it is more precise
    so far i did not find a medium class equipment for grinding, under a base cnc, at least at walter-ewag
  1. HAWEMAT2000/5 ECO TOOL CUTTER & GRINDING MACHINE
    By majidtaher in forum Want To Buy...Need help!
    Last Post: 05-01-2015, 05:39 PM
  2. Please recommend a parting tool
    By mike82 in forum Mini Lathe
    Last Post: 01-16-2013, 08:14 AM
  3. Please recommend me a machine !
    By jerzyk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-23-2012, 03:48 AM
  4. Recommend us a machine please
    By UWAM in forum Australia, New Zealand Club House
    Last Post: 09-12-2012, 01:56 PM
  5. Grinding tool bits
    By cncadmin in forum DNC Problems and Solutions
    Last Post: 08-16-2003, 03:06 AM
