I have an Eldorado Tri Power with the OEM compound. I, for the life of me, can not figure out how to make this compound cut a taper.
I have it mounted to the tool post and then a cutting tool in the compound. The problem is that it seems that it should be pointing at a 90 degree angle to what it is. It is the tool is perfectly in line with the travel of the compound which makes it impossible to cut a taper. When you look at a video of someone cutting a taper with a compound it seems that the tool is at a certain angle to the compound, this doesn't seem possible with the one that hangs on the tool post as the tool angle is not adjustable to the slide. Its straight or nothing so how on earth do you cut a taper? What is the compound even for in this case??
PLEASE HELP ME BEFORE I LOSE MY MIND!!!
