587,321 active members*
3,067 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, what is G23 Torque limit check command ?
Results 1 to 4 of 4
    Jun 2015
    4156
    Jun 2015
    4156
    Re: please, what is G23 Torque limit check command ?
    post 64 in here : http://www.cnczone.com/forums/okuma/...tor-stuff.html
    if i knew that i will find an answer so fast, i would have not opened this thread
    there is not many infos about it inside the osp300 manuals, but somehow i thougth to replace G22 with G23 so to see what happens
    this is not the 1st time i ask about G23, but is definetly the last time
    this thread can be deleted i aprove it !
    Jul 2010
    287
    Please reference section 3-5: Torque Limit and Torque Skip Function
    Pages 40-43 in the manual I keep at my desk:
    P300S/P300L
    Programming manual
    9th Edition
    LE33-019-R9
    Pub# 5946-E-R8
    dated October 2015
    I believe it is ver-batum what the P200 i used to keep said.
    Jun 2015
    4156
    hei teahole / i just looked, and i only have the 6th edition
    pages are the same 40-43, and i bet that their content is the same if so, there is no info about G23 in there, but only a show-up at SECTION 15 APPENDIX, 15-1 G code list
    did you used G23 ?
    Quote Originally Posted by tea hole View Post
    one moment, to google that latin i dont know, you are reffering to nice infos in older manuals, that is no longer inside newer ones ?
  1. Limit Switch Check
    By ohanasailing in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-25-2014, 10:55 PM
  2. G31 P99 servo torque limit skip
    By nracingdev in forum Fanuc
    Last Post: 11-23-2013, 10:26 PM
  3. Replies: 1
    Last Post: 11-22-2013, 11:35 PM
  4. Torque limit?
    By tunitime in forum Okuma
    Last Post: 05-25-2011, 08:05 PM
  5. How do you check/test/measure step motor torque ?
    By Calico in forum Stepper Motors / Drives
    Last Post: 05-09-2005, 11:51 PM
