587,770 active members*
3,247 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, is there a system variable for rapid droop ?
Hybrid View
    Jun 2015
    4160
    hello pls, is there a system variable for rapid droop ( like vinp* ) ? attached image
    and what are these :
    ... VIPXD, VIPXE, VIPXF : Droop amount in XD-axis ( XE , XF)
    ... VIPZD, VIPZE, VIPZF : Droop amount in ZD-axis ( ZE , ZF ) ? kindly
    Apr 2009
    1262
    Re: pls, is there a system variable for rapid droop ?
    Nope. Not that I've ever heard about.
    Experience is what you get just after you needed it.
    Jun 2015
    4160
    hey mr Wizard i have runned some trials ( tring to reduce indexing time + others ), but i could not reduce program time by using "droop" and/or "rapid droop"
    it seems that lathes are moving as fast as possible, without messing with those droops ( probably thats why G64 is default, and also "rapid droop" is disabled )
    "rapid droop" = "droop" only when a rapid is involved, and allows a larger ipw (=10mm); how my clearances are pretty low ( 1-2.5mm at toolpath begin, and 0.3mm at toolpath end ), i think i dont need "rapid droop" / kindly
  1. Taig - xylotex variable rapid rates
    By cscheide in forum Taig Mills / Lathes
    Last Post: 10-30-2015, 11:41 PM
  2. Dry-run system variable?
    By machzero in forum Okuma
    Last Post: 05-21-2015, 01:13 PM
  3. system variable for tool in spindle
    By ggborgen in forum Fanuc
    Last Post: 07-15-2010, 07:29 AM
  4. System Variable for Pallet in thr machine
    Last Post: 06-12-2010, 01:58 AM
  5. System Variable For Pallet In The Machine
    By ggborgen in forum Parametric Programing
    Last Post: 01-16-2010, 06:45 PM
