587,853 active members*
3,764 visitors online*
    Feb 2013
    10
    plunge milling
    How do you plunge mill with 2.5D? thanks
    Jan 2007
    1795
    Re: plunge milling
    what I know ""plunge milling""
    3d surfaces roughed out with a short drillbit, that don't flexing, for more efficient roughing..
    if you like to simulate this in 2.5 D and you don't have solidworks or similar program, then I think the simplest is filling the pocketing area with circles like the drill bit diameter..
    if you want to make overlaps between drills, then you need an offset from the area inside with value the half of offset..
  1. PLUNGE MILLING
    By dcutler35 in forum Mastercam
    Last Post: 11-17-2012, 01:38 AM
  2. I need some milling/plunge bits for lathe turning
    By phawks_99 in forum Wood Lathes / Mills
    Last Post: 09-11-2011, 09:54 PM
  3. I need some milling/plunge bits for lathe turning
    By phawks_99 in forum Want To Buy...Need help!
    Last Post: 09-11-2011, 07:40 PM
  4. Plunge Milling
    By binzer in forum GibbsCAM
    Last Post: 05-29-2007, 08:31 PM
  5. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
