ok...update...been working on the z axis getting all the little details buttoned up.
working on the oil distribution manifold. Drilling the long bore down the center:
I also machined out a pocket for the test linear encoder. Drilling the cable clearance hole
This is the first time ive used this walker turner drill press since i rebuilt it. man do i love that thing!
Also added a clearance pocket for the ballscrew nut screw. This was the fist time i've used a rotary table like this. it worked pretty good
but back to that encoder, i made a simple right angle bracket to hold it. The encoder has slots in it to adjust up and down, and the bracket has slot to adjust left to right. so as long as im close at getting the magnetic tape in place i should be good to go.
looks like it'll fit so far:
next up, the locating ring for the head. drilled on the mill and bored and parted to length on the lathe.
Also got the gas strut mounts on as well as the home switch. how she sits now:
