587,175 active members*
2,921 visitors online*
    Nov 2017
    Pocket quality
    Hi. I am the new CNC operator for Precision Railings, and I am not sure where to start looking for this.
    I am working with Maple hardwood on a Basic HDX router, and one problem I am running into is the quality of the bottom of pockets. You can see where the CNC changes directions in corners, and those marks suck to sand out.
    Is the pocket quality dependent on the speed/feed settings, or is it the path settings?
    Any info or links would be appreciated.
    Dec 2011
    45
    Re: Pocket quality
    Quote Originally Posted by pugs911 View Post
    Increasing stepover may help. Otherwise can be a machine issue where the Z axis is flexing or has some play in it otherwise
    Jul 2016
    660
    Re: Pocket quality
    A sample picture says a thousand words....most of the time it`s either the tool bit you used, on my case I can cut pockets all day from soft to hard wood to metal (steel, brass aluminum, etc.) with just a single same tool bit, im the one sharpening my tool bits, custom angles depending on the material I cut.
    Your machine looks nice, and expensive too
  1. Replies: 5
    Last Post: 09-28-2017, 08:43 PM
  2. Advance Pocket or Offset Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-31-2013, 07:46 AM
  3. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  4. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  5. pocket pc
    By DONNYBRASS in forum MetalWork Discussion
    Last Post: 11-18-2007, 10:02 PM
