Dear William D,
Thank you for getting your fingers dirty. Great posts.
That counts for a lot more than my two cents.
Anyway here they are...
Production lines need to pump out the product, and whether they are building GRP boat hulls, or epoxy composites, they need to do it fast.
That means that they have to lay up the mould and get the cured product out of the mould as quickly as is economically possible. They therefore use a fast curing resin and as much catalyst as possible because it speeds up production.
This means that the exothermic reaction is probably fairly large and speeds the cure. Exotherm will be about as large as they can get away with without distorting the mould or setting fire to the facility.
In your case, as a non-production craftsman, there is really no need for speed.
IMVVHO, what you need for a successful epoxy/granite/sand mix is a mixed resin mixture that is extremely non-viscous, (ie really thin) so that it can thoroughly "wet" all parts of the aggregates as it goes into the mould, or when it is in there before it is curing.
I think that the best way to do this would be to use a really, really slow curing epoxy resin and absolutely as little catalyst as possible.
Under these conditions, you may well be able to heat the resin, catalyst and aggregates to make the mix "flow" well for some considerable period before the whole shebang starts setting up. The resin mix will become less gloopy purely due to the application of external heat. The catalyst kicks in later.
Just a thought,
Best wishes
Martin
Best wishes
Martin
