603,890 active members*
2,923 visitors online*
    Mar 2006
    21
    Portable CNC data transfer Box
    This may be the wrong thread but let’s give it a whirl! Years ago I acquire a IC memory box made by Tactc co. Ltd. of Japan called a KOALA 50. It allowed me to download to the box from a Fanuc type controller then either load into another controller or load on to a pc for editing or the reverse. It has been a handy little box and no long runs of wire are required. The problem is the battery is dead and I can't find a replacement (MAXELL LP 01A1 3.6 volt). Does anyone out there produce a box like this anymore?
    Thanks in advance!
    Jun 2011
    7
    Searching for Koala info
    I see that this post is quite old and am surprised that no one has responded. I guess we are in the dark but I have a Fanuc 15M with a NCR4A-2519 I also have a Koala 60 it works fine with an ac adapter. If the Koala 50 does not have an ac adapter port I am sure it would be quite easy to have one added to the box. I am currently looking into dcdsofware which will drip fee the Faunc. I will let you know if it works.
  1. Maho MH600E - CNC432 Data transfer problems
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2021, 11:31 AM
  2. Replies: 17
    Last Post: 07-23-2020, 10:30 AM
  3. DMC63V data transfer (ASAP)
    By sonnybiker in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-16-2008, 08:52 AM
  4. Replies: 0
    Last Post: 12-01-2007, 10:37 PM
  5. Fanuc 9M data transfer problem
    By YOO in forum Fanuc
    Last Post: 01-18-2007, 03:26 PM
