603,850 active members*
4,711 visitors online*
    Sep 2011
    9
    Position error 194 on CC200
    CC200 ... "Position error" (194) on X-axis, when max feedrate is over 4m/min - but only in one direction - after several engine rotation (a different distance each time). In the opposite direction on X-axis is speed 10m/s without any problem.
    Where could be problem ? Why one direction only ?
    Sep 2011
    9
    Re: Position error 194 on CC200
    Differently wide pulses A and B from Rod320. Fixed by changing the position of the incident light on the sensors in ROD320.
  1. Bosch CC200
    By alanser in forum Bosch Rexroth
    Last Post: 07-31-2012, 07:27 PM
  2. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  3. Alarm 194 on MDC500
    By dcoupar in forum Haas Mills
    Last Post: 04-23-2009, 06:27 PM
  4. cc200 T programming
    By WEMASERV in forum Bosch Rexroth
    Last Post: 10-20-2008, 08:03 PM
  5. Help, VF OE: alarm #194
    By teal854t in forum Haas Mills
    Last Post: 03-17-2008, 06:18 PM
