Recently completed my CNCRP4896 and cut my first parts. Did not go good. The last line of code returned the machine to X0Y0 and it faulted out by reaching the y axis limit switch. The DRO was about .75" from reaching zero. The program was about 45 minutes long and a combination of circular pockets (100 ipm) peck drilling and profile cuts (200 ipm). Needless to say the parts were quite a ways off. I suspect some very serious lost steps.
So tonight I went and investigated..
I homed the machine and ran the first segment of the program - about 3 minutes. Using the verify button in Mach3 the error was +.0005 in x and -.0486 in Y
Ran the second segment of the part - to rule out program issue. Error of -.0005 in X, -.0378 in Y.
Looked for mechanical issues on Y (loose pulleys, pinion engagement, added some tension, checked for any binding - did not find any), reduced accel values from 40 to 20 and ran a 3rd program error was x +.001 y -.0113
Changed the Look ahead in CV from 20 to 200 and ran a 4th program (little longer about 6 minutes)- Error x + .001, Y - .0839.
Chnaged CV on angles from 0 to 89. Ran 1st program again Error x +.0005, Y - .0501
Up until now all above programs were circular pockets at 40 IPM (air cuts)
Changed to Program 5 which was profiling moves 200 IPM feed. Error X +.0015, Y - .0167
Reduced Accell values from 20 to 10 Error x 0.0000 Y -.0162
Reduced accell values to 5 on Y - Error X -.0005 Y -.0201
Upped accel values to 50 on x and y and upped rapids to 500 ipm Error x -.0005 Y -.0172
Real pleased with the X axis, not so the Y
4 things: I feel these trials rule out the accel values being to high, I feel it is not a mechanical thing (binding etc) and the longer the program runs, the greater the error. Also, the error is always in the same direction on Y
So what do I check next? Is my next step to swap a stepper motor out on Y and check that? Check voltage perhaps...Suggestions?
Thanks for the Help everyone.
Dan
