586,061 active members*
4,596 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > possibility to use a spindle (max 18K RPM) to drive a lathe (3000 rpm) for metals?
    Jan 2022
    11
    Hey guys!
    I have purchased a 3KW square ER20 air cooled spindle, with a maximum of 18.000 RPM, to use in my CNC router machine.
    But i ended up using another spindle for the cnc router, this time water-cooled, and as time passed i can't return the ER20 3kW anymore.
    I was wondering if i could use this spindle for a lathe, reducing the rpm and increasing the torque with Aluminum GT2 gears and a belt, to achieve a max of 3K rpm in the lathe chuck. But would this be possible? Isn't 18.000 RPM too much for these gears? How can I achieve this successfuly? or do i need another motor (servo, for example) for this application?
    Thank you for your answers!
    Jan 2018
    1516
    Re: possibility to use a spindle (max 18K RPM) to drive a lathe (3000 rpm) for metals
    I wouldn't bother trying.
    Just get a servo and your power is guaranteed.
    You'd need to gear down the 18k by a factor of 6 so you could end up with an undesirably large pulley on the chuck rear. Plus it's not guaranteed to be any good.
  1. Replies: 5
    Last Post: 05-18-2022, 03:41 PM
  2. Max Spindle rpm with interlock disengaged
    By hamtag in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2015, 08:28 PM
  3. Sanity check -- spindle temperature after running at 3000 RPM
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 08-04-2010, 06:32 AM
  4. LB-15 max spindle rpm
    By nlh in forum Okuma
    Last Post: 10-01-2008, 05:45 PM
  5. harmonic drive, max RPM stepper or servo
    By Art Ransom in forum Mechanical Calculations/Engineering Design
    Last Post: 12-12-2006, 05:26 AM
