603,959 active members*
2,831 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > POST 2 SEQUENCE NUMBER ON THE SAME LINE
    Nov 2012
    8
    HI
    CAN SOMEONE CAN HELP ME TO MODIFY MY POST FOR OKUMA CADET MATE 4020 ON MASTERCAM X4
    I GOT 2 PROBLEM WITH IT,
    THE FIRST IS THAT I HAVE 2 SEQUENCE NUMBER ON THE SAME LINE
    EX:
    N322 G2 X-2.7648 Y1.5963 I.5672 J.0203
    N323 G3 X-2.902 Y2.1085 I-.3247 J.1875
    N324 G1 Z.1 F50.0
    N325 G0 Z.25
    N326 X-3.277 Y1.459 N326 a90.
    N327 Z.1
    N328 G1 Z-.3667 F30.0
    AND THE SECOND PROBLEM, IT POST A "M" ALONE ON A DRILL CYCLE
    EX: N395 G81 X-2.2733 Y1.3125 Z0. R.1 F4.1 M0
    WHAT IS THE CHANGE TO DO IN MY POST???
    THANKS
    Dec 2008
    3216
    Welcome to the "zone"
    It seems you have done a bit of editing on a PC.... so as a suggestion, TURN THE CAPS LOCK OFF when writing messages.......it is considered as yelling.
    You will need to attach your post, as the issue can be in a number of places
    ( to attach a file in the zone must meet certain criteria. ... the main one for you is that it cannot end in ".PST" ......
    ....so copy the post to a compressed folder [.ZIP] and then upload that with your next message.... another method is to add .TXT on the end & upload that file directly )
    The M0 on the end of a drill cycle seems to be added from within your operation ( not a post issue ), it's placement refers to "canned text", so look at that area ( you may have added it accidently )
    Nov 2012
    8
    here is the post
    Dec 2008
    3216
    Quote Originally Posted by MAINVIST View Post
    EX:N326 X-3.277 Y1.459 N326 a90.
    OK, I have modified your post
    --- whoever edited it ( French, by the looks ), did not know what they were doing
    --- this looks like an old V8 post, try and get a more up-to-date post, has better code output, neater code, better programming, sub-routines etc.
    Lower case rotary address, now upper case
    invalid command removed,----- there are a lot more still in the post
    - M at the end of a canned cycle is now fixed, they commented out the possibility of an M54 ( initial level equalling retract level )
    Modified post is attached
    search for my member-name for the area I have worked on.
    Attached Files Attached Files
  1. Sequence number not found
    By Darth Yoda in forum G-Code Programing
    Last Post: 03-09-2013, 08:09 AM
  2. no line number in comment line in mpos
    By MSFAB in forum Surfcam
    Last Post: 02-13-2012, 11:51 PM
  3. Sequence Number Before Every Tool Change
    By seattle77 in forum Post Processors for MC
    Last Post: 07-16-2009, 03:28 PM
  4. omit line number
    By asjad in forum Mastercam
    Last Post: 05-10-2007, 12:18 PM
  5. Line Number Range Error
    By gar in forum Haas Mills
    Last Post: 05-23-2006, 11:06 PM
