Our cam and or code wizard versions are different - still no % at top of program. The files you modified will not open with our version of code wizard.
Can you tell me what you changed maybe we do it here.
I will try![]()
1. Under “Chavalier Mill --> NC Style, G-Codes and Modality --> Set Up Sheet
Turn ON the "Output Setup Header / Trailer"
2. Under “Chavalier Mill --> NC Style, G-Codes and Modality --> Code Constructors --> NC Program General --> Set-Up Header
Delete all the text in the output bar and plase the % symbol
3. Under "Chavalier Mill --> NC Style, G-Codes and Modality --> Code Constructors --> NC Program General --> Set-Up Trailer
Delete all the text and leave it empty
Then save it and compile. Then run out an code and check it![]()
Good luck!![]()
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Don't think this is the most correct way to do it, but i think it will work. The % symbol should be in the top in the "Program Start" but the tool list is been posted out before that...
So that is because i put it in the Header text...![]()
AHH Yes!!! May I heap praise upon you, I am not worthy...
Output looks just like we want it.
The reason for all this is our DNC software does not want to see anything above the % character
we don't like editing programs
we still want our operators to be able to see the tool descriptions list
Perfect! Thanks!
I understand that![]()
- Robert
