603,546 active members*
4,115 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > post processor changing axis name
Results 1 to 6 of 6
    Feb 2010
    4
    Good morning everyone, I have a problem, I have a Daewoo Doosan 2100 with a Fanuc 0i-f and that has a rotative table on axis Z and then the z and x, I'm able to have a proper gcode in Madcam but not in Rhinocam, in Madcam there is the option to tell to postprocessor which is the axe 1, 2, 3 and was easy for me to invert Z and X plus put 2 as multiplier on X because the Fanuc need the Diameters. the only close result i had is to setupo a 4 axis machine then I cancelled the Y in the post processor, but in this way I obtain a gcode that is Z and C and some X but I need X and C and some Z. Is there a way to to tel to postprocessor to call Z as X and X as Z? I'm using a radial tool in my Doosan so basically it is parallel to X axe, while on all the preset machines on rhinocam the axe is parallel to Z. I think there are 2 options available... invert the Z and X axes on postprocessor or find a way to have a tool parallel to X and rotary table on Z. I hope someone can help me...
    Apr 2004
    5949
    Re: post processor changing axis name
    Have you asked Mecsoft's tech support about this? That's what they're there for, and free tech support is included with RhinoCAM.
    Andrew Werby
    Website
    Feb 2010
    4
    Yes I asked at the online support some weeks ago, they told there was no way to have a gcode in X C Z and with the orientation as i wanted it,... in the end yesterday evening I manage to do it with a modified 4 axis machine but with a post processor with only X C and Z axes plus some tweacking to change X and Z output and diameters instead of rays, in the end it was not impossible.
    Apr 2004
    5949
    That's great. You should get back with the tech guy and explain how you did it - it might help the next person who has this problem.
    Andrew Werby
    Website
    Feb 2010
    4
    I already sent him the postprocessor file.
    Aug 2009
    I have the same problem with the post processor. Do you still have the post processor so I can see how you did it?
  1. Changing the default post processor
    By dkrenfrow in forum Mastercam
    Last Post: 12-15-2015, 10:47 AM
  2. Replies: 2
    Last Post: 10-06-2015, 03:40 PM
  3. Changing the default post processor...
    By DavidMc0 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  4. Post Processor: Changing the format of feed output.
    By somebodyelse in forum CamBam
    Last Post: 01-16-2014, 03:33 PM
  5. changing a post processor
    By fourperf in forum Fadal
    Last Post: 06-16-2007, 04:48 PM
