588,166 active members*
4,351 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Post Processor crashes with long path names
Results 1 to 13 of 13
    Jul 2005
    194
    Version 27.
    If I have a long path, ANY post processor apart from ones like Generic Router will crash. I can save the same GCODE file to a shorter folder name and it works. Anybody else see this? Is this a known issue?
    If I take out the line with the
    "(FILE: ",prog_name,")"
    Then the post processor works just fine.
    Re: Post Processor crashes with long path names
    I don't have 27 but it sounds like you're running up against file path name length issues.
    If you create a desktop folder or one in the root of My Documents does the problem still occur?
    What happens when you then copy the file using Windows to the folder where you'd like it to reside?
    - Nick
    Jul 2005
    194
    All those things work if the path is shorter and windows has no issue with copying the file. I have an especially long customer name and project and that makes for a long path name.
    So this fails
    /users/MachineShop/desktop/dropbox/customers/OregonIndustralLaser/AR15Jigs/GCode/LowerReceiverDriversSideJig.tap
    But
    /users/MachineShop/desktop/dropbox/LowerReceiverDriversSideJig.tap
    works as well as just copying the file.
    I use Dropbox to sync my GCode out to the shop computers.
    Dec 2013
    290
    move the dropbox folder to the root c directory? That would shorten your path location quite a bit.You could then place a shortcut on your desktop if you want, to that folder location.
    Jul 2005
    194
    I made a shortcut to that project to in in my "libraries", I think that's the best as the path is short and it's right there. When I am done with this job I can just delete it out of my library.
    Apr 2008
    1577
    I created a file with a path and filename like this and it posted without issue in my standard post processor.
    C:\XXX\XXX\29089\buried\burid\buried\buried\buried \buried\buried\buried\buried\buried\buried\buried\ buried\buried\buried\deeper\2908929089290892908929 08929089.bbcd
    I think there is something else that my be going on. Are you posting to a network location or anything else out of the ordinary?
    Jun 2008
    1838
    Didn`t we have an issue with long file names a few years ago, think it was the old clunky V22, if memory serves it was Burrman who solved it last time
    Hope it`s not something that`s rearing it`s ugly head again
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Apr 2009
    3376
    Quote Originally Posted by KSky View Post
    So this fails
    But
    FWIW,you spelled "Industrial" wrong.Not trying to be smart,,just an observation.
    Probably nothing there.
    Jul 2005
    194
    Quote Originally Posted by SBC Cycle View Post
    Hmm, what post processor are you using? There are a few that don't print the filename in the output that work for me.
    Dec 2008
    4548
    Mine says this:
    "(PROGRAM NAME - ",prog_name,")"
    And it only outputs the filename in the code. Not the entire path.
    What post are you using that has THAT.....
    Jul 2005
    194
    Quote Originally Posted by BurrMan View Post
    Mine says this:
    The "Tormach_PCNC_1100_Rev1.MillPst, but I get the same message using the Fanuc0M.MillPst right out of the box. And your right, it's just the file name.
    Apr 2009
    3376
    Not having the correct machine selected will throw that code.
    Make sure your machine is selected under current settings
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Or more specifically the "nc filepath" under the machines settings needs looked at...
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. Win/DOS long and short file names - problem
    By DaveDoesIT in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-20-2012, 04:44 PM
  3. path code to S post
    By Steve Manthey in forum Surfcam
    Last Post: 02-16-2009, 04:26 AM
  4. Bad Luck??? (long post)
    By Brad Morris in forum Mori Seiki Mills
    Last Post: 10-26-2008, 03:24 AM
