603,963 active members*
2,135 visitors online*
Results 1 to 13 of 13
    May 2003
    267
    Post Processor for Powermill & Mach3
    Here is a Post Processor file that can be used within Powermill for the Mach3 controller. I got this from a friend.
    I tried it out myself and it works for me. Please note that I did not test every feature of the post processor file.
    Attached Files Attached Files
    Oct 2007
    5
    That's great. What cad/cam does it work with?
    May 2003
    267
    It works with the Delcam Powermill software which is a CAM product. I used Solidworks for the CAD, but works for any CAD. The machine controller used is Mach3.
    The post processor is specific to Powermill and Mach3.
    Jun 2010
    sir help me
    i need delcam postprocessor for anilam 1100 M please help dear.please send if anyone my brother have it. at [email protected].
    Oct 2013
    [QUOTE=georgebarr;607900]Here is a Post Processor file that can be used within Powermill for the Mach3 controller. I got this from a friend.
    hi , i tried this fanuc custom1b with powermill 9 and whenever i load the post file into the software it say a broken post and corrupt file
    so do you have any idea why tis happens or with what version of powermill
    Mar 2013
    3
    Re: Post Processor for Powermill & Mach3
    how do i install this pmopt file?
    Feb 2011
    212
    This post produces mass amount of lines that are not needed
    here is a simple program and the file it post out
    N10( NC FILE : 2 )
    N20( DATE : 10.02.15 dd/mm/yy & TIME - 13:53:59 )
    N30( PMPost VERSION : 6.3.2579.0 )
    N40( MACHINE TOOL : --- & MODEL : --- )
    N50( CONTROLLER : Fanuc & SERIES : --- )
    N60( OPTION FILE : fanuc-custom1G )
    N70( OUTPUT WP : World )
    N80( OUTPUT UNITS : MM)
    N90( MIN X: -59.4, MAX X: 59.4, MIN Y: -20.665, MAX Y: 12.665, MIN Z: -28.5, MAX Z: 0.3 )
    N100( SPINDLE SPEED: S1500)
    N110( PLUNGE FEED RATE: F1 )
    N120( SKIM RATE: 3000 )
    N130( CUTTING RATE : 1000 )
    N140( COOLANT MODE: M8 )
    N150( TOOLPATH LENGTH: 118.8 )
    N160( TOOLPATH CUTTING DURATION : CUTTING TIME : 9.25 )
    N170( OPTION FILE : fanuc-custom1G)
    N180( This post processor is compatible with the Mach3 controller using inches unit of measure.)
    N190( G40: Cancel cutter radius compensation)
    N200G40
    N210( G17: Select XY plane-default)
    N220G17
    N230( G80: Cancel modal motion to ensure axis motion is not occurring)
    N240G80
    N250( G49: Cancel tool length compensation)
    N260G49
    N270( G20: Use inches for length units)
    N280G20
    N290( G90.1: Absolute distance mode for IJK)
    N300G90.1
    N310( G92.1: Coordinate systems offset to zero)
    N320G92.1
    N330( G94: Units per minute mode, used in feed rates)
    N340G94
    N350( G0: Rapid linear motion)
    N360G0
    N370( G90: Absolute distance mode for XYZ)
    N380G90
    N390( G50: Reset scale factor of all axis to 1.0)
    N400G50
    N410( G52: Reset coordinate system offset)
    N420G52 X0 Y0 Z0
    N430( G53: Move in absolute coordinates. But first, use G90-absolute distance mode for XYZ)
    N440G53
    N450( G69: Cancel rotate coordinate system)
    N460G69
    N470( G10 L1: Set tool offset values to zero for tool #1..20 max of 253, Z-height, A-tool tip radius, X-diameter)
    N480( But first, need radius, G40, and length, G49, cutter compensation turned off)
    N490G10 L1 P1 Z0 A0 X0
    N500G10 L1 P2 Z0 A0 X0
    N510G10 L1 P3 Z0 A0 X0
    N520G10 L1 P4 Z0 A0 X0
    N530G10 L1 P5 Z0 A0 X0
    N540G10 L1 P6 Z0 A0 X0
    N550G10 L1 P7 Z0 A0 X0
    N560G10 L1 P8 Z0 A0 X0
    N570G10 L1 P9 Z0 A0 X0
    N580G10 L1 P10 Z0 A0 X0
    N590G10 L1 P11 Z0 A0 X0
    N600G10 L1 P12 Z0 A0 X0
    N610G10 L1 P13 Z0 A0 X0
    N620G10 L1 P14 Z0 A0 X0
    N630G10 L1 P15 Z0 A0 X0
    N640G10 L1 P16 Z0 A0 X0
    N650G10 L1 P17 Z0 A0 X0
    N660G10 L1 P18 Z0 A0 X0
    N670G10 L1 P19 Z0 A0 X0
    N680G10 L1 P20 Z0 A0 X0
    N690( G10 L2: Set the fixture offset values to zero for fixture #1..10 max of 253)
    N700( But first, need to use G90-absolute distance)
    N710G10 L2 P1 X0 Y0 Z0 A0 B0 C0
    N720G10 L2 P2 X0 Y0 Z0 A0 B0 C0
    N730G10 L2 P3 X0 Y0 Z0 A0 B0 C0
    N740G10 L2 P4 X0 Y0 Z0 A0 B0 C0
    N750G10 L2 P5 X0 Y0 Z0 A0 B0 C0
    N760G10 L2 P6 X0 Y0 Z0 A0 B0 C0
    N770G10 L2 P7 X0 Y0 Z0 A0 B0 C0
    N780G10 L2 P8 X0 Y0 Z0 A0 B0 C0
    N790G10 L2 P9 X0 Y0 Z0 A0 B0 C0
    N800G10 L2 P10 X0 Y0 Z0 A0 B0 C0
    N810( ---)
    N820( ================= )
    N830( TOOLPATH : 1 )
    N840( STRATEGY USED : Raster )
    N850( TOOLPATH WP : World )
    N860( ================= )
    N870( TOOL TYPE : ENDMILL )
    N880( TOOL NAME : T16e )
    N890( TOOL DIA.: 12.7 & TIP RAD.: 0 & LENGTH : 90.36 )
    N900T16M6
    N910G54G90
    N920S1500M3
    N930M8
    N940G0X0Y-4.
    N950G43Z10.H16
    N960X-59.4Y-19.
    N970Z5.2
    N980G1Z.2F60
    N990X59.4
    N1000G0Z10.
    N1010M9
    N1020( G91: Incrementally move tool )
    N1030G91Z4
    N1040( G90: Absolute distance mode for XYZ )
    N1050G90
    N1060( G49: Cancel tool length compensation )
    N1070G49H0
    N1080( M30: Program end and rewind )
    N1090M30
    N1100( --- )
    N1110%
    Can any one edit this pmopt file so it post out only hat I need ?
    T16M6
    G54G90
    S1500M3
    M8
    G0X0Y-4.
    G43Z10.H16
    X-59.4Y-19.
    Z5.2
    G1Z.2F60
    X59.4
    G0Z10.
    M9
    M5
    M30
    hello friend i need help, i need mach3 + A and B pmoptz file, If you have someone, please give me a linkthank you!
    Hi i need fanuc15m.opt if any one have would you send me
    hello i need delcam ductpost
    if any one can help me
    Feb 2019
    Hello,
    does anyone have the powermill opt file for mach3 ??
    Thanks a lot
    Apr 2017
    does it works with 4 axis?
    Quote Originally Posted by georgebarr View Post
    Dear I do it but I see the "Broken connection" error. I try again with just "fanuc" and it is possible.
    What is problem?
  1. 5axis post processor for powermill
    By ekashfi in forum Post Processor Files
    Last Post: 05-13-2016, 04:07 PM
  2. Problem with Powermill and Post processor 4800
    By Miletoo86 in forum PowerMILL
    Last Post: 10-08-2013, 04:28 PM
  3. Generic Post Processor for Powermill 10?
    By microbeast29 in forum PowerMILL
    Last Post: 02-06-2011, 01:20 PM
