603,967 active members*
1,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > post processor for HAAS vf2 (bobcad)
Results 1 to 7 of 7
    Jan 2007
    46
    I desperatly need the bobcad (version 21) post processor for a haas vf2 that was revised on jan. 2007. The only one I can find on their website is the older one.
    I tryed to call all day and never heard back from them.
    I know this is available because I used to have it.
    Thanks for any help, Joe
    Sep 2006
    340
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    That's a great website. Sorin is a standup guy. Bobcad should help you out but getting ahold of them is a problem sometimes. Good luck. Curtis.
    Sep 2006
    340
    I never had a problem getting in touch with them, BUT I always have troubles getting RID of the BCC sales staff?
    Thanks Marc
    Dec 2005
    121
    The Haas post that is on the website is the latest post . We had to create 1 haas VF post that worked and remove all the older versions. They should have been done this way in the past so there was no confusion on which to use . This post has been verifyed to work . And has not had any trouble . If you need the Haas post that was Labeled 1-15-07 Please email me at [email protected] and I will contact you on were to download from.
    Jan 2007
    46
    Thanks for the help, I discovered after finally getting ahold of tech support this morning that the reason the processor was not work was because of the way I loaded the post.
    You need to save it to your computer first, then run it.
    If you hit "run" as you download the post will load into bobcad with errors.
    Would be nice if they mention this in their download section.
    Joe
    Sep 2006
    340
    Actually most people Dload it to a folder in case they crash the computer.... That way you will not loose the processor? If you have made changes to the processor please do youself a favor and back it up in another location and call it the modified one....
    Thanks Marc
  1. bobcad post processor for turbocnc
    By Pbrew1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2018, 08:26 PM
  2. post processor for HAAS vf2
    By joesimmers in forum BobCad-Cam
    Last Post: 12-11-2007, 03:07 AM
  3. BobCad-Cam v19 post processor installation
    By goodeye in forum BobCad-Cam
    Last Post: 11-24-2007, 03:33 AM
  4. BobCAD-CAM v17 post processor help
    By johnmac in forum BobCad-Cam
    Last Post: 10-10-2007, 09:29 PM
