588,129 active members*
4,791 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Post Processors ?
    Let me start by saying that I admittedly know very little about post processors and g-code, yes I should know more but it will take a bit of time for me. I do however have quite a few close friends that are very well versed in this area and having been doing this for 20-30 years and are always willing to help me out. This was the case last night.
    I loaded in PP and right away had problems with programs that I ran just the day before with no issues. What I don't understand is how Tormach can say that if a processor worked in Mach3 that it will work with PP, when at least in my case, it did not work without modifying the processor quite a bit. I'm using Bobcam for Solidworks V4 and Tormach can say whatever they want about it, but there were no issues with it in Mach, in fact my buddy looked through many of my programs and said that Bobcam was spitting out code exactly as it should be and all the problems he found were within PP itself
    He did get my processor modified to where it would work but had to change it so that it was tricking it into working, most of the issues were to do with cutter comp, for some reason PP except they Bobcam calculates lead in's and out's. Again, I never had a issue with Mach3 and in the end I had to load Mach back in because I need to get work done and even though he got the post working, I can't risk something not working In the middle of a job and waiting until my buddy gets home to come over and check It out.
    Don't get me wrong I'm not bashing Tormach or PP, I think the interface is great and once all issues are resolved I can't wait until I can run it.
    My question is, is anyone else having issues with their post processors and if so, what are the issues? I have looked on the issue tracker and I don't see any of the problems I'm having and I'm curious to see if it is bobcam, but like I said code looks fine and I never had one single problem with Mach and the stock Tormach post they provide was never modified before
    and like I said, I'm no bashing anyone I just am trying to see if others have similar issues. I would hate to find out that PP will not function correctly with Bobcam even after it is fully released
    Kyle
    Jul 2004
    1424
    Re: Post Processors ?
    That is the problem with jumping on "beta software"; you become unpaid help in the debugging process prior to commercial release. OK if you are a hobbyist, but probably not OK if you depend on your machine to make money. Hopefully Tormach will get these issues straightened out soon and release the final product.
    Why is BobCAD using cutter comp? That seems strange, since CAM should easily calculate required cutting geometry that accounts for cutter diameters without having to use cutter comp. IMHO, cutter comp is only to make hand coding easier.
    Doubly strange since cutter comp doesn't work right in MACH3, so I am surprised that BOBCAM g-code with cutter comp would have worked correctly previously.
    I have two words for you "HSM Express". Awesome integrated CAM software for SW.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Bobcam has the options to use system comp or machine comp, so it works either way.
    HSMexpess was what I was using but I need 3D and 4 axis and HSMworks price is way out of my range
    Quote Originally Posted by tmarks11 View Post
    Jul 2004
    1424
    Quote Originally Posted by Concepts_Design View Post
    Yep, that will do it.
    If you turn off machine comp in BobCAD, doe the post-processor work with PP? I don't see any advantage to using cutter comp when using CAM to generate g-code for your Tormach.
    Tim
    even with machine comp turned off it still didn't work with the original post. after modifying it quite a bit it would work, but PP didn't like any of the lead in's and out's so it was still throwing errors
    Jun 2014
    1780
    Sprutcam also works well, I had a transformation tapping entry it didnt like, but selecting each of the holes it worked fine. I have one other error but it ignores that one, but it does shows up in the status line.
    Sprut will do 4th axis and 3d and it is reasonably priced.
    mike sr
    need for it to run within solidwork though, for now I've just gone back to mach3 until PP becomes more stable
    Quote Originally Posted by popspipes View Post
    Jun 2014
    1780
    I have never use cutter comp, I just size the tool accordingly in cam, seems to work fine.
    mike sr
    Jul 2004
    1424
    This was the issue of the arc radius being too tight from PP point of view?
    Post an error on their beta webpage and see what they say.
    I didn't realize that BOBCAM offered a plug-in for SW. What do you think about it vs. the HSM Express that you had used for 2.5D?
    Tim
    Jun 2005
    655
    The regular Bobcad Mach post needed tweaking to run with PP but only to add things like the G64 and take out some of the illegal codes that Mach ignored.
    Yes, I believe it was, however it pretty much wouldn't allow any type of arc lead in
    Good point, did not think of this and I will do it. no sense in beta testing if I'm not reporting the issues
    Without a doubt HSM is so much better than BobCam, but the cost is so much higher as well. Bobcam will pretty much do everything HSM does but they have a whole bunch of little quirks that will drive you nuts and takes a bit more work to make it happen , documentation on Bobcam is horrible, however their tech support team is great. Also when making small modeling changes, BC does not automatically update the tool paths like HSM, you have to force it to do so which means reselecting geometry, reselecting boundaries and updating tool path parameters. And this is for all tool paths, not just the ones affected by the model changes
    Quote Originally Posted by shred View Post
    that may be the case with bobcad, but for bobcam for solidworks it was much more than that. I would have thought that their posts would be the same but maybe since my version runs in Solidworks they are different
    Jun 2006
    3063
    SprutCAM has an add-in for SolidWorks as well as several other CAD systems. I don't think that the part model is updated in SprutCAM if it is changed in CAD, though.
    Mike
    Aug 2009
    294
    First part with PathPilot 1.6, first error. For some reason it does not like this line from Sprut:
    N80 G0 G94 X0.375 Y-0.475 Z0.1 H1
    It gives me an error saying, "G-Code error near line: 21. H word with no G43 or G76 to use it.
    Any ideas?
    Jul 2004
    1424
    Well the H1 is the height offset of the tool, which would be set with G43. It should be in the same line as a G43. But that is not the only issue...
    It is really weird to set that offset in anything other than a tool change line (i.e. M06), as changing the offset generally only happens when the tool changes, and that line has the height set at 0.1", so it could be a disaster waiting to happen if you tried to fix it by simply putting a G43 in front of it.
    Is there a tool change line (M06) in the line before it?
    Tim
    Aug 2009
    294
    Here is the first tool operation. I guess I'm wondering why this worked with Mach and not with PP?
    ORear Suspension Mount
    (Tool) (2) (Diameter)(0.098) (@.098" Drill Bit) (Operation) (Hole machining)
    (Tool) (3) (Diameter)(0.12) (@.120" Drill Bit) (Operation) (Hole machining2)
    (Tool) (1) (Diameter)(0.25) (@.250" Endmill) (Operation) (Roughing waterline)
    (Tool) (1) (Diameter)(0.25) (@.250" Endmill) (Operation) (2D contouring)
    (Tool) (1) (Diameter)(0.25) (@.250" Endmill) (Operation) (Pocketing)
    (Tool) (4) (Diameter)(0.25) (@45 degree chamfer) (Operation) (2D contouring2)
    N10 (Postprocessor: )
    N20 G90 G54 G64 G50 G17 G40 G80 G49
    N30 G20 (Inch)
    (Hole machining)
    N40 G54
    N50 M998
    N60 T2 G43 H2 M6
    (.098" Drill Bit)
    N70 S10000 M3
    N90 G0 M8
    N100 G98 G83 Z-0.45 R0.1 Q0.125 F42.6 P0.5
    N110 X2.125
    N120 G80
    N130 M5 M9 (Inch)
    N140 (Inch)
    (Hole machining2)
    N150 M998
    N160 T3 G43 H3 M6
  17. #17
    Aug 2009
    294
    This is why I don't understand the Mach post processor not working...it's from the PP FAQ:
    Will my CAM systems Mach3 postprocessor work with PathPilot?
    Yes, it will. PathPilot and Mach3 share the same syntax, with the exception of subroutine programming.
    Has this changed? Is there a new post?
  18. #18
    Jan 2013
    97
    Quote Originally Posted by C*H*U*D View Post
    If it was legally formatted g-code coming out of the same post processor, it won't have a problem. Mach let you get away with some "illegal" formatting, PP won't. That's why you're having the issue.
  19. #19
    Aug 2009
    294
    Quote Originally Posted by Philbobb View Post
    So then, what Tormach said in the FAQ is incorrect. PathPilot will not work with the Mach post processor for SprutCAM.
  20. #20
    Jan 2013
    97
    I would call Tormach to see if they have an updated post, or if they can tell you how to modify it.
Page 1 of 2 12
  1. Post processors....
    By jame5m28 in forum Uncategorised CAM Discussion
    Last Post: 02-19-2024, 01:07 AM
  2. post processors?
    By john_t_h in forum Syil Products
    Last Post: 11-26-2018, 05:01 AM
  3. how do I set my post processors
    By Alan0166 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  4. What are post processors?
    By raworkshop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2009, 12:10 PM
  5. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
