first of all, sry If its an absolute obvious question (and I hope so)
But im fairly new to this.
Today I calculated my first paths in bobcad/cam on an external stl model
I used advanced roughing and the paths are just fine.
I downloaded the metric mach3 postprocessor and also set the NC-path correctly
The problem is that it only outputs this:
Can anybody give me a hint what Im doing wrong?Code:(BEGIN PREDATOR NC HEADER) (MACH_FILE=3AXVMILL_MM.MCH) (MTOOL T1 S1 D10. H80. DIAM_OFFSET 1 = 5.) (SBOX X0. Y0. Z-20. L220. W60. H0.) (END PREDATOR NC HEADER) % O1000 (PROGRAM NUMBER) (PROGRAM NAME - MSSWORDNC) (POST - MACH 3 MILL NO ATC METRIC) (DATE - WED. 10/12/2011) (TIME - 01:24AM) N01 G21 G40 G49 G54 G80 G90 G91.1 (JOB 1 ZLEVEL ROUGH) (FEATURE ADVANCED ROUGH) (N02 T1) N03 S2 M03 N11707 M09 N11708 M05 N11709 M02 (END OF PROGRAM) N11710 M30 %
Thanks and greetings from Vienna!
//Edit: And no this is not the demo! (but it behaves like it.., maybe there is something wrong with the licensing)
