603,960 active members*
2,555 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > postprocessor for adapted cnc machine ( mastercam )
    Oct 2005
    5
    Lightbulb postprocessor for adapted cnc machine ( mastercam )
    hello every one!!!!
    i'm having a big problem trying to make(modify) a postprocessor to a adapted convencional lathe machine. to a CNC whith 2 tool to drill at the same time in the same piece.
    the holes to do is simetrical, so the piece rotate in C axis, and the drills are posicioned in X and Y axis, and move cuttind in Z axis.
    Mastercam version: X2
    The controler is fanuc-OT
    example from code accepted:
    O2770
    N0001 G90 (PROG ABS)
    N0002 M54 (ASPIR ON)
    N0003 M32 (REFRIGERATION X ON)
    N0004 M33 (REFRIGERATION Y ON)
    N0005 G55
    N0006 T03 (2 SHORT DRILL D 8)
    N0007 G00 G43 H03 Z20.000 S2000 M08
    N0008 G00 G90 C0.000
    N0009 G00 X69.000 Y69.000
    N0010 M24 (MOTOR X ON)
    N0011 M25 (MOTOR Y ON)
    N0012 G00 G90 C10.000
    N0013 M98 P171001
    N0016 M28 (MOTOR X OFF)
    N0017 M29 (MOTOR Y OFF)
    N0018 G00 G90 Z250.000
    N0019 G00 G90 C0.000 M09
    N0020 M00 (stop)
    N0026 M30
    O1001
    N0226 G90
    N0227 G00 Z5.000
    N0228 G01 Z-4.000 F100
    N0229 G01 Z-25.000 F200
    N0230 G00 Z5.000
    N0231 G91 C10.000
    N0232 M99
    drawing of axis:
    my problem:
    - output from mastercam to gcode the line :
    - outut the correct angle in C axis:
    anyone have any idea?
    i already have contacted my mastercam resseler, but he don't give me no positive feedback. So, i don't want to give up so easly....
    tanks in advance for any sugestion, and sorry for my poor english...
    Oct 2005
    5
    nobody?......
    Jun 2005
    305
    OK, Since nobody has offered to help you...
    I really do not see anything wrong with your code except your drawing shows 140mm bolt circle and your code gives 138mm diameter.
    Please post an example of the code you are getting from MasterCam and a copy of the post file you are trying to modify and I will take a look at it.
    If you can, please post a copy of your MasterCam file in V9 format.
    I can not promise a quick fix but, I will try.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. mastercam x2 postprocessor
    By bizdad in forum Mastercam
    Last Post: 10-12-2008, 11:05 AM
  2. mastercam postprocessor 5 axis
    By pgman68 in forum Post Processor Files
    Last Post: 05-07-2008, 02:26 AM
