603,890 active members*
3,063 visitors online*
Results 1 to 8 of 8
    Feb 2006
    3
    Postprocessor for EdgeCAM
    Hi all, I'm new here
    and I hope I am on right place :-) I can't configure EdgeCAM 10 to generate code for Hurco VMX1 (Basic level of NC code). Does anyone have a postprocessor that is able to create NC code for VMX1 or any advice how to set up EdgeCAM's post processor?
    Many thanks for any help!
    Ales
    P.S. forgive me for my english :-)
    Mar 2004
    174
    send me some example g-code for your machine that includes drilling,tapping, etc... and i will see if any of my posts are a close match.
    www.cncfusion.com CNC kits for Sieg mills and lathes
    Feb 2006
    3
    Use you code wizard, you can find some examples that come with it.
    It's not that bad to change values, if you have a dealer that you bought the software from he should hook you up.
    Good luck.
    Feb 2006
    3
    Thank you for replies. I have no example of working g-code still, because I have CNC machine for few days only. But I probably found mistake, it was in using compensations - I didn't know that machine compensation (G41) doesn't need to use. I use compensation by pathtrace and now I can meanwhile work until I obtain regular postprocessor from EdgeCAM dealer.
    Feb 2006
    3
    Smile
    No problem, you will find that using centre line with comp a great feature, it allows you to go into rads that are smaller the rad with out going into alarm.
    Mar 2006
    4
    Hello..
    goodbye
    Sep 2005
    197
    This may help?
    I found two post for Hurrco maybe they are close to what you need.
    The first is for Hurrco ultimax 3
    The Hurrco is forHurco VM1,VCM40 & VCM50. don't know anything about these post so you try them at you own responsibility
    Attached Files Attached Files
    Feb 2006
    3
    Quote Originally Posted by smoregrava View Post
    Thank you, it is what I needed.
