603,954 active members*
3,301 visitors online*
Results 1 to 5 of 5
    Apr 2025
    4
    Postprocessor for PowerMill
    Dear colleagues,
    I’m currently working with PowerMill and looking for a compatible postprocessor that works reliably with PlanetCNC (CNC USB Controller software). If anyone has experience using PowerMill with PlanetCNC, I would greatly appreciate your recommendations.
    Which standard or custom PowerMill postprocessor works best for PlanetCNC?
    Are there any known compatibility issues or required modifications?
    If possible, could you share a sample postprocessor or direct me to a resource?
    Thank you in advance for your support!
    Nov 2013
    52
    Re: Postprocessor for PowerMill
    Using a China CNC Router G Code ATC (mm) (*.tap) works well for me.
    Hope that helps.
    Apr 2025
    4
    I didn't quite understand the answer — how is it related to PowerMill?
    Nov 2013
    52
    You were enquiring about a compatible postprocessor that works reliably with PlanetCNC USB, I have provided one that works for me and thousands of others!
    Apr 2025
    4
    I don't have this post-processor in the list. Could you send it to me here? I would really appreciate it.
    Mar 2017
    1495
    Fanuc, Mach or LinuxCNC postprocessor might work. G-Code is compatible but avoid using cycles.
