603,355 active members*
4,051 visitors online*
Results 1 to 15 of 15
    Apr 2013
    110
    PostProcessors Vectric
    I tried the PostProcessors for Vectric inserted in the 20/12 version of TNG but I get an error; I use Aspire 9.0.
    I tried to understand more by reading the Post Processor Guide attached to Aspire but without result :-(
    Mar 2017
    1495
    Re: PostProcessors Vectric
    This variable works in Aspire 10. You can safely comment or delete it.
    Apr 2013
    110
    Grazie.
    In effetti, questa guida non ha fatto menzione di questa variabile; Avevo pensato di eliminarlo ma non ne ero sicuro.
    Feb 2019
    76
    What is the name of the postprocessor for the vectric?
    USBCNC?
    Apr 2013
    110
    C: \ Programmi \ PlanetCNC \ Samples \ Postprocessors \ Vectric
    PlanetCNC_inch.pp
    PlanetCNC_mm.pp
    Feb 2019
    76
    OK
    I don’t understand how to delete a message. Stupid site, the first time I see this.
    Mar 2017
    1495
    Postprocessors for Vectric are included with TNG software. They are in Samples/Postprocessors folder.
    Dec 2008
    16
    Hello,
    I will re-use this topic for issue reporting. I was trying to use this script in Vectric 6 PRO. So I have copied PlanetCNC_mm.pp into C:/ProgramData/Vectric/VCarve Pro/V6.0/PostP/.
    During starting there are multiple errors showed.
    Attachment 439522
    Code:
    +VAR DWELL_TIME = [DWELL|A|P|1.2]
    After commented this out it showed next error.
    Attachment 439524
    Code:
    +VAR INVERSE_TIME = [FI|A| F|1.2]
    Last comment and next error.
    Attachment 439526
    Code:
    +begin DWELL_MOVE
    +"G04 [DWELL]"
    After last comment, Vectric started-up successfully. So what is the right way to use this? I am not really sure if can make this or not.
    Thank you
    Mar 2017
    1495
    I guess VCarve6 is too old and does not support these variables.
    Dec 2008
    16
    Quote Originally Posted by PlanetCNC View Post
    Thank you, so what is the min supported version?
    Dec 2008
    16
    Quote Originally Posted by Deklos View Post
    I have verified, that output from Aspire 9 and my commented code are the same.
    hey guys, where can i download the current post processor for vetric aspire mm. it only has inch
    Feb 2011
    154
    It is a part of install files. Take a look to: c:ProgramFiles\PlanetCNC\Samples\Postprocessors\Ve ctric
    Just came across this thread a bit late, but thought I’d share something helpful for anyone using Vectric Aspire with Planet CNC in millimeters.
    As you probably know, the default post processor is in inches. If you need a millimeter version, just copy the post processor file and paste it into ChatGPT. Ask it to convert the file to millimeters and generate a new post processor file for you.
    Important: Make sure you also ask it to include a post name in the file—otherwise it won’t work properly in Aspire.
    Hope this helps someone
    Feb 2011
    154
    I don't think is nedeed, because in folder: "c:\Program Files\PlanetCNC\Samples\Postprocessors\Vectric\" is both PP inch and mm, at least I have them both ....
  1. Postprocessors
    By MrSolution in forum EdgeCam
    Last Post: 12-05-2019, 12:45 AM
  2. postprocessors
    By bolton78 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-13-2012, 02:30 PM
  3. Postprocessors
    By the_paco in forum SprutCAM
    Last Post: 03-27-2012, 07:34 AM
  4. Postprocessors
    By cordic in forum G-Code Programing
    Last Post: 09-30-2011, 12:12 AM
  5. Postprocessors?
    By frist in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-14-2010, 09:16 AM
