587,999 active members*
2,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Power Draw Bar and Table Mounted Rack Tool Changer?
Results 1 to 6 of 6
    Jul 2004
    595
    An earlier post got me thinking...
    How hard would it be to make a simple table mounted rack tool changer if you have the power draw bar?
    Ive seen a few on this forum. I wonder if there are any plans that could be adapted? Anyone working on this?
    David
    Jun 2006
    2512
    Jun 2006
    2512
    Jul 2009
    147
    I have trouble getting my collets to come out of the spindel (tapping on the bolt with the wrecnh is not enough) is any one else run into this?
    Jan 2007
    1332
    Quote Originally Posted by davidperry3 View Post
    I am running the Tormach power draw bar (beta version) and have not had that problem unless there is not enough air pressure with the draw bolt adjustment. If that is the case then I just back off on the draw bar tightness for the air pressure used. Then all of the TTS tools release easily.
    Don
    Mar 2008
    331
    Contact Hoss on the forum here. The times I ve talked to him he is very helpful and knowledgeable.
    http://www.hossmachine.info/
  1. Power Draw Bar
    By GT150 in forum Benchtop Machines
    Last Post: 12-11-2008, 10:52 PM
  2. rack tool changer software
    By Zig in forum G-Code Programing
    Last Post: 04-10-2008, 10:52 PM
  3. Anyone mounted a power drawbar to their X4?
    By MadMax in forum Syil Products
    Last Post: 04-02-2008, 07:36 AM
  4. Vertical mounted router table?
    By 307startup in forum DIY CNC Router Table Machines
    Last Post: 02-09-2007, 04:37 AM
