While I had the camera out taking photos of my upgraded coolant system I decided to shoot some of the power drawbar I designed and built.
I used a air over hydraulic system because I wanted maximum holding force for the TTS toolholders. I had too many pullouts caused by chatter (with longer endmills), etc. and wanted to be able to walk away from the machine with full confidence that when I return I won't find the cutter buried in the vise or table. I designed the system as a single stroke, quick acting, hydraulic actuator that can provide in excess of 10,000 lbs. drawbar force with 90 psi of air and minimal volume. (A 7/16-20 grade bolt is rated at 10,660 lbs of force). It is operated by flipping a toggle switch under the head (1st photo) and has an electrical interlock to prevent it from being actuated when the spindle is turning. I have been using it for roughly 2 years now without a single problem.
