Hi everyone
I planning to build 4×8 laser cnc laser cutter.Highest working material will be MS sheets around 3-5mm.
Can anybody suggest me power of laser tube i should buy.
Sent from my Redmi Note 3 using Tapatalk
Hi everyone
Yes dude
i didnot see anything, which laser tube power?
Now i got it , if you want to cut 3-5mm mild steel, i suggest you to use the fiber laser 500W, then you can get a good effect, but if you think the cost is high, you also can choose a plasma machine, then it will cost much less,
if you want to buy then let me know , i can give you good one
