587,281 active members*
4,954 visitors online*
Results 1 to 7 of 7
    Apr 2009
    134
    power rectifier circuit
    I am having some trouble with "simple" power rectifier.
    Have one 24V transformer but when I mesure voltage after rectifier and capacitors i get as much as 38V.
    i have 2x1000uF capacitors connected.
    How do I get rid of the extra voltage??
    Dont know if you can understand my problem because my english is not so god...
    Mar 2004
    1806
    Zeed,
    The 24 V AC is measured at rms voltage which is .707 of the peak voltage and the DC voltage is the peak voltage of the system. In order to get "rid" of the excess voltage, you need to reduce the "ac" voltage. DC voltage of this "simple" unregulated voltage is 1.4 times the ac voltage.
    Hope this helps.
    Art
    AKA Country Bubba (Older Than Dirt)
    Mar 2008
    267
    What are Your requirements?
    X VDC at Y Amp?
    Dec 2003
    24223
    One efficient way to reduce the voltage if possible is to reduce the secondary winding, i.e take turns off, typical is 2~3 turns/volt.
    The secondary is usually wound last so it could be as simple as this.
    Al.
    Albert E.
    Dec 2005
    1408
    Dear Zeed,
    It would help us if you could let us know what DC voltage you would like, and also the DC current that the circuit will need. Could you send us details of your transformer? Are you using a bridge rectifier circuit for the power supply?
    If you can tell us that, there are plenty of people who can help here. There really are, and they will do so gladly. All we need is a bit more information.
    Best wishes,
    Martin
    Apr 2009
    134
    Thank you all for answering.
    This is salvaged transformer with multiple outputs so I just took 18V instead 24V...It has 12,18,24 and 32V outputs.
    Now I got 20,4V dc after the rectifier.
    "DC voltage of this "simple" unregulated voltage is 1.4 times the ac voltage. "
    I learned something new today
    My driver board can only take 24V so this will be OK.
    I tried to connect it to 25V and one of the capacitors on the board went to heaven....
    Thank you again.
    Dec 2003
    24223
    18v ac should give you nearer to 24+ than 20.4DC, unless you had no cap connected?
    If so the result will be pulsed DC. 120Hz ripple, or 100hz on 50Hz supply.
    Al.
    Albert E.
  1. Regenerative power dump circuit
    By contactirfu in forum UHU Servo Controllers
    Last Post: 06-02-2014, 07:48 PM
  2. Bridgeport mill power supply circuit
    By JohnDG in forum CNC Machine Related Electronics
    Last Post: 06-25-2009, 04:34 PM
  3. HELP Power supply broken... Bridge rectifier smokes... Coil heats up.
    By Delanoman in forum DNC Problems and Solutions
    Last Post: 04-07-2009, 04:19 AM
  4. How hard is it to figure out the size of cap and bridge rectifier for a power supply
    By journeyonline in forum CNC Machine Related Electronics
    Last Post: 04-04-2007, 10:31 PM
  5. Switch Mode Rectifier as power supply
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 04:17 AM
