hi all im confused as to what sort of power supply i should use
to run a hobbycnc 3 axis driver and 200oz/in steppers from the hobbycnc web page
a 24v pc power supply or what else can i use ?
i want to get the best performance out of them
cheers
tom
cheers
tom
He (Dave, HobbyCNC) recommends a couple and gives links on his site but some of us made ours out of old microwave transformers. The rewinding is not too difficult if you're not a stickler for appearances. Bubba tells how here:
http://www.cnczone.com/forums/showpo...1&postcount=14
Use a 36V power supply for best performance.Originally Posted by tomcook
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
The Hammond 30vac xmfr Dave recommends will give you about the max voltage the board can handle (30 vac x about 1.4 for going thru the ac/dc conversion = 42-44 vdc. The board handles 44 vdc max).
Dave
