588,245 active members*
4,349 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Power supply for 3 x (75V, 6A) ac servo motors
Results 1 to 19 of 19
    Oct 2005
    375
    Hello people,
    If i want to power 3 servo motors with a continues current of 2A
    and a max current of 6A. (motors run on 75V)
    Can i just say 3 x 6A = 18A needed?
    Or can i use a lower amerage power supply (2/3) x 18 = 12A...?
    (that is done with steppers sometimes)
    could somebody explain this to me?
    Greetz,
    Roy
    Dec 2003
    24220
    Normally your system should be designed and motors sized to operate in the continuous area of operation.
    Are you considering a Linear supply or switching type?
    Linear are somewhat more tolerant of intermittent current peaks, but with a proper system you normally would not even see the constant current rating x3 at any given instant in normal operation.
    Al.
    Albert E.
    Oct 2005
    375
    Hey Al,
    you are right and got me thinking again..
    Designed the servo system for continues operation.
    Calculated the linear and rotational inertia of moving parts and ballscrews incl, bearing resistance etc. Also made a calculation for the tangential force needed for the milling operation. (max. 6mm endmill diameter)
    During maximum material removal and acceleration of table, the needed torque at the servo is at nominal level, so that is ok.
    So i only need a FOS to make sure, think 1,5 will do.
    What about the linear or switching power supply. for the servo`s i will use a linear i think.
    But i also got another question:
    For the spindle motor i use a nice small Maxon motor (36V, 3,6A nominal)
    Here the drive uses the full Voltage from the power supply and this defines the max. spindle rpm. (speed mode with only hall feedback)
    I want the spindle speed at the right rpm, for this case i would like to use a switching power supply and this power supply defines my spindle speed, but now you say that a rapid change in rpm cann cause trouble. How about that?
    If i over design the switching power supply (amps), would this give less trouble?
    Dec 2003
    24220
    Is this a DC brushed Maxon motor or BLDC?
    Are you using the hall feedback just for tach purposes?
    What controller are you using?
    You could use a 40vdc supply and just regulate the maximum rpm, if using a tach, then you should have rpm control.
    I find linear supplies are generally more rugged and easier to fix.
    Over designing current wise is no problem, just less efficient, power wise.
    Al.
    Albert E.
    Oct 2005
    375
    Read the manual again and dont know for sure how the drive works.
    I want to use a max. rpm of 30.000 rpm.
    On the drive i can select a rpm range from 1000 to 30.000 rpm by a dipswitch.
    The motor is 737 rpm/V, thus:
    30.000/737=40,7V
    The drive can control the rpm by a analog input from 0.5 to 5 V
    If i would use a power supply of 48V (drive max is 50V), would this result in a max speed of 30.000 rpm? Since this is the max with the dipswitch setting for 1 pole pair motor, or will the max rpm be 48x737=35300rpm
    Think i can just use a switching 48V supply (10A, drives max) and use the dipswitch till 30.000rpm, then the rpm will never be higher than 30.000rpm?
    Page 5 gives this:
    Note:
    The power supply must be able to buffer the back-fed energy from STOP or di-rection change operations e.g. in a capacitor.
    With electronically stabilized power supply units it must be ensured, that the over-current protection responds in no operating condition.
    Meaning that a Switching power supply can be used..?
    Attached Files Attached Files
    Dec 2003
    24220
    As far as I can tell by the PDF's although the drive will operate a 1 pole pair motor up to 60,000rpm, the EC-32 motor itself is rated for <15,000 rpm?
    What it is saying is that if you use a switching supply and back EMF exceeds the tolerance of the supply it should be capable of shutting down.
    One more reason to use a linear?
    Al.
    Albert E.
    Oct 2005
    375
    The motor is rated to max. 25.000 rpm, atleast, the bearings.
    Maxon told me 30.000 rpm would be possible, but bearing life will reduce.
    If i use the 30.000 setting instead of 60.000, the drive will stop at 30.000rpm even if the voltage is higher. (hope so)
    Dont understand what the EMF is in regards to a switching power supply.
    Dec 2003
    24220
    Energy reflected back from the motor in the deceleration (generation) mode that may cause the effect stated on the page #5 note you show and mentions the supply must be able to cope with it.
    Al.
    Albert E.
    Oct 2005
    375
    Will look into it a little bit further and contact maxon.
    Think then that the linear supply will be the best solution.\\Greetz,
    Roy
    Dec 2003
    24220
    Out of interest what is the spindle going on or being used for?
    Al.
    Albert E.
    Oct 2005
    375
    A nice small benchtop machine (outer dimensions 450x450x450mm)
    xyz cube 200x100x90mm, base of epoxy granite (German EG shop will fill the mould with a good EG and vibrate it)
    Got almost all the components except the steel parts.
    [ame=http://www.youtube.com/watch?v=Q0BTHGUXlXk&feature=player_embedded]CNC Mill - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails Last mill 2010.jpg   1.JPG   DSCF7728.jpg   3.jpg
    Feb 2006
    101
    Awesome, unique looking build. Are you documenting it anywhere? After a lot reading on cnczone, and I wanted to build something similar - a small, but rigid, machine with an EG base/frame.
    Oct 2005
    375
    No documentation so far, yeah on the Dutch cnczone.nl. But thats hard to read i think..
    If you look in my post or started threads you can find a lot more design, this one is final.
    When finished i will make a design/build thread, i have calculated eveything with hand and also FEM. Think i will show all but are not sure because maybe i want to start a company one day.
    Dec 2003
    24220
    The link is dead!
    What is the details of the spindle itseslf, I have not made anything this small but I have a surplus of parts I am thinking of doing something with along the same lines.
    Al.
    Albert E.
    Oct 2005
    375
    Spindle is very nice:
    max rpm: 60.000
    Runout in cone: <0.001mm
    Diameter; 30mm
    Length: 50mm
    4 ceramic ac bearings, max 6mm endmill
    NSK NR3060S
    NR-3060S
    But expensive
    Dec 2003
    24220
    What do you estimate you maximum drilling/milling capacity to be?
    Al.
    Albert E.
  17. #17
    Oct 2005
    375
    not much, there are tables based on the standard spindle motor.
    They can be found in the Nsk cataloge.
  18. #18
    Dec 2003
    24220
    I was just curious as you seem to have designed for extreme rigidity, would you need that much for that spindle?
    Al.
    Albert E.
  19. #19
    Oct 2005
    375
    You are right Al, for the NSK spindle the machine is too much.
    Did the calculations for the NSK spindle using equations from this book:
    Engineering formulas for metalcutting from Edmund Isakov ISBN: 0-8311-3174-8
    From this book i calculated the tangential force with a 6mm endmill machining aluminum 7075-T6, 1x1mm removal. This resulted in 50N force or something from my head.
    This spindle is only for precise machining and not rapid material removal.
    Next to the NSK spindle i have designed a ER20 spindle that i can use on the same machine for machining square block and also to setup for a small gangturn vertical lathe.
    I want to use this machine to make small parts for rc car racing. The EG base is far overdesigned for each case, the steel parts show in worstcase situation less the 0.001mm deflection, that was the goal.
    Offcourse the FEM simulations give nice pictures and have to looked at with a grain of salt..I used it to get a direction on what was happening in the construction.
  1. Servo motors rated at 85volts power supply at 100volts?
    By CATCH22 in forum Servo Motors / Drives
    Last Post: 01-15-2012, 05:13 AM
  2. Is it mach 3, power supply or motors?
    By tauscnc in forum Mach Mill
    Last Post: 12-06-2008, 03:17 PM
  3. Question about power supply for the motors
    By SteveC68 in forum CNC Wire Foam Cutter Machines
    Last Post: 03-29-2008, 02:45 AM
  4. Help with Power supply or motors ?
    By rodzilla in forum Stepper Motors / Drives
    Last Post: 11-29-2007, 04:58 PM
  5. Power supply for 3 xylotex motors
    By PEU in forum CNC Machine Related Electronics
    Last Post: 06-18-2005, 07:07 PM
