603,360 active members*
4,852 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Power Supply for Geckodrive
Results 1 to 8 of 8
    Sep 2004
    7
    I have a Nema 34 size of motor.It has a 6 amp per phase curent of consumption.White paper tells that a power supply must hase the 2/3 rated curent of motor i.e. 4 amp.But in microstepping mode is two windings of motor to connect to the power supply at the same time i.e. power supply must hase 12 amp of load current.What does power supply uses in may application in this case?
    Mar 2003
    35494
    The 4a per motor is all you will need.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2004
    2849
    So, you'll use max. current when you are stepping at max. speed and when you are holding a position (hmmmmm.....I should look at some stepper charts). Anyway if you have a larger supply then required it certainly won't hurt.
    Mar 2003
    35494
    Quoted from the White Papers at Geckodrive.com:
    "The easiest factor in choosing a power supply is its current rating. The current rating of the supply is based on your motor choice. The drive will always draw less than 2/3 of the motor’s rated current when it is parallel (or half-winding) connected and 1/3 of the motor’s rated current when it is series (or full-winding) connected. That is to say, a 6 Amp / phase motor will require a 4 Amp rated supply when parallel connected and a 2 Amp rated supply when series connected. If multiple motors and drives are used, add the current requirements of each to arrive at the total power supply current rating."
    This information specifically applies to Geckos. Other types of drives may or may not follow the above rules.
    Gerry
    Nov 2004
    14
    Hello,
    Where can I get the components to build a 72v@25 amps power supply from either 120 or 240 ac, to power my three servo's from my 320 gecko's?
    Thanks,
    Larry
    P.S. I believe I have posted this in the wrong area, any help would be greatly appreciated.
    Aug 2004
    2849
    Quote Originally Posted by plateroomred
    Hello,
    Thanks,
    Larry
    Ebay...look for toroids that have a secondary rating of 50 volts....why 72 VDC....what's the rating of the servo?
    Oct 2004
    742
    Don't forget that the output voltage of a DC supply (after being rectified and filtered) will be 1.414 times the transformer output voltage (AC).
    A transformer with a 72 Volt AC output will give a DC output of approximately 101.80 Volts DC. A transformer with an output of 50 VAC will have a voltage of 70.7 Volts DC after the rectifiers and filter capacitor(s).
    May 2003
    132
    Smile power supply
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Diy Power Supply Choices
    By berin in forum DIY CNC Router Table Machines
    Last Post: 07-13-2005, 09:47 PM
  3. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  4. Is this power supply rating adequate?
    By jerryrigge in forum CNC Machine Related Electronics
    Last Post: 11-25-2004, 05:06 PM
  5. Choosing a Power Supply for Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2004, 04:36 AM
